Starter removal 1986 Toyota truck
Old Apr 10, 2014 | 12:08 PM
mikesta's Avatar
I thought I asked this before, searched my posts, searched the entire forum, google etc. I'm doing it wrong.
Seems that my starter is in the engine bay tight. What is the trick to removing it from the engine bay? I've done it before... just don't recall how.
Old Apr 10, 2014 | 12:53 PM
toyota4x4907's Avatar
Unbolt it?.....
Drop it out the bottom. It would make things easier to unbolt the clutch slave from the bell housing. I was able to take it out through the wheel well of my 4Runner but it had a 2" bodylift
Old Apr 10, 2014 | 06:06 PM
85sr5excab's Avatar
I'm pretty sure I've pulled mine out thru the top. I unbolted the top bolts from the engine bay and the bottom from underneath the truck. Unhook the wires and pull it out the top. Assuming u have a 4 cyl. I have no experience with the 3.0.
Old Apr 11, 2014 | 06:18 AM
SnowVan's Avatar
22re unblock and pull through passenger wheel well. remove rubber and plastic fender walls if youre having difficulty (careful these bolts break tho.)
Old Apr 11, 2014 | 07:29 AM
mikesta's Avatar
I've tried them all, there is no way to get it out. I did it on a 3.0 mh before, on this one, I think the trans cooler lines need to be unmounted and then slid out the bottom.
This is a 1986 22re Toyota truck (RV)
Old Apr 11, 2014 | 07:53 AM
redbayredneck's Avatar
It took me over an hour of fighting it and trying different methods to remove it... I don't remember exactly how it came out, but I'm pretty sure I pulled it out of the top on my '85.
Once you get it out, putting the new one in is as easy as reversing the process
matrad
Aug 26, 2024 08:21 AM
voiddweller
19
May 2, 2016 09:10 PM
DacodaYota
Sep 2, 2015 02:13 PM
bigblue82
10
Jul 6, 2015 08:27 AM
UKMyers
9
Jun 15, 2002 12:57 PM
