Starter problems / electrical problem
Old Jan 19, 2010 | 01:32 PM
1990yota-pickup's Avatar
thats... is usally the voltage reg.. but put a mulitmeter on your alt.. while its running see what the actual volts are.. good question...
Old Jan 19, 2010 | 03:58 PM
desertcamper67's Avatar
Originally Posted by 1990yota-pickup
check every wire in that truck..
make sure you don't have a bad ground or a broken wire.. get in there and trouble shoot it.. read your trouble shooting procedures.. in your haynes manual..
if not make up your own after you figure it out...
Originally Posted by carb85
OH NO! That was not my day!
15 minutes before a potential buyer wanted to come over for a testdrive my starter motor died. When I turned the key it just made "click, click, click, click,click" (approximately six times in one second). The engine did not crank.
Then we decided to do the testdrive by bump-starting the engine. On the testdrive the voltage sometimes dropped down rapidly:
1. Revcounter went to zero although engine was running in idle.
2. Radio turned off sometimes.
3. When the engine was in idle and the testdriver switched the headlights on, the engine stalled.
I already disassembled the starter motor and will test it with an ohmmeter tomorrow.
Three questions:
1. Does anybody have an idea what else could cause the problem?
2. Could I drive my 4Runner around without the "starter motor assembly" attached to the gearbox? Or would oil sprinkle around while I am driving around?
3. The cover of the small fusebox is missing since I bought my 4Runner (22R engine). Can anybody say what these three fuses do? And: Where are CMH and HEAD attached to?
I don't know if this helps but I had a broken wire from the battery to the nearby fusebox you have pictured on the passenger fender. There was only one strand of wire still connected causing all sorts of intermitten problems. I don't know if it is an actual fusable link or regular wire but I just put in a butt connector in place of the break.
Old Jan 20, 2010 | 11:35 AM
weaselman's Avatar
Originally Posted by 4reigner
not meaning to jump your thread,just a quick related question: Would a tired alternator cause the volt meter in the dash to go up and down with the turn signals on?
Had some starting issues myself, recently, but have been wondering about the pulsing of the gauge when i indicate... Thought it might be related?
Cheers
mine has done this from the day i owned it (like 4 years).
And my alt has been replaced 4-5 times.
I just thought it was always normal..
Old Jan 20, 2010 | 01:26 PM
my old truck used to have problems like this all the time and it came down to plug thay plugged into the back of the alt.. put a new plug on it and problem happend again...
Yota.Jay
Jul 23, 2015 08:08 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
kyletbert
Jul 17, 2015 11:39 AM
Poncho0206
Jul 10, 2015 06:21 PM
colinmil
Jul 6, 2015 04:03 PM
