Starter fix
Old Mar 15, 2009 | 07:12 PM
Matt16's Avatar
Originally Posted by scuba
yyyeeeep, Just did this on the taco a couple weeks back.
Fixed my starting problems...And alot cheaper then a new aisin starter.
didnt even think once about a remaned one from vatozone..
Yeah, those starters are upwards of a grand IIRC. You only need the one contact (the other shouldn't have much wear). The fix was twenty buck. That opens the season on 500+ cold Rickards Reds.
Old Mar 15, 2009 | 07:14 PM
scuba's Avatar
bahah, the ground side didnt have much wear, but I had already special ordered the part and opened it, and while I was in there I might as well change it too...
Old Mar 15, 2009 | 07:17 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Was that before or after you wrecked the taco?
Old Mar 15, 2009 | 07:28 PM
874runnersr5's Avatar
rickards white > rickards red
Old Mar 15, 2009 | 07:31 PM
  #25
Junkers88's Avatar
That has got to be the best reason on the planet to fix things yourself.
Of course you need to change that picture into a Bud Light or since I'm sittin here tipin to some ol' EazyE we could slip in a 40 of Old E..........
Old Mar 15, 2009 | 07:39 PM
  #26
scuba's Avatar
ITS NOT WRECKED, ITs DAMAGED !!
and FTR it was before..
Old Mar 15, 2009 | 07:53 PM
  #27
Tomato......taaamato. Same difference N thing.....
Old Mar 15, 2009 | 07:56 PM
  #28
Jay351's Avatar
I found the starter R&R job was easy. Hardest part was my dealer giving me one of the wrong contacts. It was different but worked with some filing.
I had it done in less then an hour.
Good write up Matt!
Old Mar 16, 2009 | 12:57 AM
  #29
Matt16's Avatar
No way, I could never figure out what i was tasting in White, but I didn't like it as much. I like their Honey Lager as well. Its a good before-noon beer on fishing trips.
Old Mar 16, 2009 | 09:34 PM
  #30
chrisrudd's Avatar
Red face
I replaced my contacts at the same time I pulled my transmission. It's not easy to get the starter through the access panel with all the wires in the way, but it's an easy fix once you get it out. I got 2 contacts from toyota for $10. The plunger was in pretty good shape, so I didn't replace it. They wanted $30 bucks, but mine was in good shape. It's an easy fix for a common problem.
Old Mar 17, 2009 | 10:57 AM
  #31
Matt16's Avatar
$10 for both?! They wanted $54 at my dealership.
Old Mar 17, 2009 | 11:02 AM
  #32
scuba's Avatar
I payed 28 for my set...
Old Mar 17, 2009 | 11:13 AM
  #33
ospartier's Avatar
Good info. I always removed the oil filter to get that top bolt out. I never thought about the charcoal filter.
Old Mar 17, 2009 | 11:35 AM
  #34
Matt16's Avatar
Yeah that would be a good idea. I have a big York air compressor that sits where the AC compressor is mounted so that wouldn't have worked, but it would on everyone else's engine.
izzmee
Aug 17, 2015 10:20 AM
Dakotaneu
Aug 15, 2015 07:24 AM
clok
Aug 1, 2015 09:42 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
colinmil
Jul 6, 2015 04:03 PM
