Stabilizer Bar
Old Oct 10, 2011 | 01:07 PM
bobjohnson2121's Avatar
Stabilizer Bar
My driver side stabilizer bar is busted, and I am looking to replace it. I have a 92 pickup with a 5 inch suspension lift and 3 inch body lift. Does anyone know if the stabilizer bar would still be stock and I could get one from the dealer? I measured it, and it was roughly 5.5 inches. The lift is from super lift, so if the part isn't stock should I try them, or are there any other suggestions?
Thanks for the help. It's much appreciated.
Old Oct 10, 2011 | 01:08 PM
Sorry, maybe "stabilizer bar" wasn't the right term... pin or link might be the correct term. Anyway, hope you guys can tell from the picture.
Old Oct 10, 2011 | 02:14 PM
AZ89LONGBED's Avatar
Just the end-links of the swaybar. Take the old one into NAPA & have them match it, shouldn't be more than 20 bucks to do both sides. Factory Service Manual says to torque those bolts at 9 ft-lbs
Old Oct 10, 2011 | 04:22 PM
wd21_sr5's Avatar
those style sway bar links are cheap, just get a pair from your local parts store (NAPA, CarQuest, whoever you like), or if you want to get super fancy I think Energy Suspension makes kits with pairs of them and poly bushings (generally available at a lot of parts stores as well)
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
A2theK
Oct 14, 2015 07:10 AM
Obmi
Oct 4, 2015 11:30 AM
Pocoyota
Sep 8, 2015 02:41 PM
