SR5 Cluster
Old Aug 8, 2008 | 03:47 AM
Tool Pants's Avatar
I put a 1989 SR5 cluster from a 4Runner in my 1988 pickup last year. The SR5 cluster had a lot more miles than my pickup. I saw the instructions on how to open it up like above, but instead I started to do it with an electric hand drill. When I saw how long it was going to take I put the cluster under my drill press and let it run for hours. Guess I could have driven in reverse for a few years and had the same result....
When the SR5 cluster matched my pickup I stopped, and put it in.
I was told by a non Toyota mechanic that I did not need to do any DMV paper work because the replacement SR5 cluster now had the same mileage as my original cluster. I never checked with the DMV to see if he was right.
Old Aug 8, 2008 | 09:06 AM
Trustyrusty's Avatar
What did you use so it didn't drill a hole in the cluster? How did you do that exatcly?
Old Aug 8, 2008 | 03:51 PM
Tool Pants's Avatar
I just looked at my pictures from last year. When I said the SR5 cluster had a lot more miles, it was only about 4,000 miles more than the original. Not a lot of miles like I said. I thought it was more because it took so long to rollback 4,000 miles. Normal people would not have bothered on a 20 year old vehicle.
My original 1988 pickup cluster had 150,462 miles on it. The 1989 4Runner cluster had 154,885 miles on it. I have owned the 1988 since 1989 and I wanted the 4Runner numbers to match. A normal person would not care.
If you do not have a mechanical odometer then you are in the wrong place.
A speedometer cable has a square end. So does the pointy end of a nail. I first tried it with a hand electric drill. Once I realized I would have to hold the trigger down for years I switched to the drill press on the highest speed it had.
The drill press method.
The drill press method took forever for just 4,000 miles. I was expecting the drill press motor to burn out for being on for so long.
Here are both clusters together after the rollback of the 1989 SR5 cluster. They have the same mileage.
Old Aug 8, 2008 | 08:36 PM
cunninglinguist's Avatar
someone should roll theirs FORWARD to 900,000
Old Aug 14, 2008 | 07:37 PM
  #25
MCMLXIX's Avatar
I just purchased an 88 truck and the speedo doesn't work at all... What do I need to do to swap in an SR5 dash with tach and guages? Is it Plug and Play?
Old Aug 14, 2008 | 08:10 PM
  #26
just a 22re's Avatar
i was thinking about taking mine back to 000000000 or maybe 999999900 and just roll it out lol
Old Sep 21, 2008 | 10:03 AM
  #27
Tool Pants's Avatar
I finally did a quick search on the Califonia DMV site. The reason is I own a Porsche with an electronic cluster and it is somewhat common to swap clusters for the higher end model cluster in order to get extra guages. A new cluster is about $1,500 so most of the swaps are done with a used cluster. For about $150 a shop can reset the mileage of the donor cluster to match the vehicle it is going into.
One of the Porsche owners swapped clusters a few years ago and the donor cluster has a lot less miles. He did not have the odometer reset. He did not do the paperwork at the time of the swap. He had smog inspections done with the original cluster and then with the donor. Mileage is reported to the DMV for a smog inspection. His problem is that a Carfax report now shows an inconsistent odometer alert.
So I got curious on the rules.
California Vehicle Code Section 28053. (a) Nothing in this article prevents the service, repair, or replacement of an odometer, if the mileage indicated thereon remains the same as before the service, repair, or replacement. If the odometer is incapable of registering the same mileage as before the service, repair, or replacement, the odometer shall be adjusted to read zero and a notice in writing shall be attached to the left doorframe of the vehicle by the person performing the service, repair, or replacement specifying the mileage prior to the service, repair or replacement of the odometer and the date on which it was serviced, repaired, or replaced.
So what I was told last year by a mechanic when I did my SR5 cluster swap is true. I did not have to do any paperwork because when I put in the SR5 cluster it had the same mileage as my original.
Another thing I learned is that when you sell a vehicle that is 10 years or older you do not have to report the mileage to the DMV.
Old Sep 21, 2008 | 04:35 PM
  #28
^^^^ thus true
buts how did you ever find an odom with the SAME miles as yours??
Old Sep 22, 2008 | 03:37 AM
  #29
Myron's Avatar
Lots of write ups on that...just search it
Old Sep 23, 2008 | 07:09 PM
  #30
Hey Just A 22RE I tried takin my needle off again, and it just flat out will NOT come off, I popped the black plastic cover part of the speedo needle off and thats cause I pried it off, then I put vice grips on the needle, heated it with a lighter, and pulled on it while holding it with my feet.. no luck..
Old Sep 25, 2008 | 05:47 PM
  #31
just like this flat head screw driver under the pointer and turn it should just pop right off!!
  #32
ok im going to make a very crapy and short VIDEO of how to do this step by set ok
matmattmatthew
10
Feb 9, 2021 04:15 PM
reallynotamechanic
Sep 20, 2015 05:40 PM
87SR5justin
Sep 15, 2015 06:48 PM
imhousing
Sep 10, 2015 02:04 PM
Rawwdz
Sep 6, 2015 09:03 PM
