sputtering at idle and while coasting only
Old Oct 31, 2008 | 12:24 PM
99ncxj's Avatar
swapped out the wires and seemed to help some. Not as bad as before but still skips on idle. Did the paperclip jump thing and pulled codes off my check engine light.
4-1 and 5-1
I belive the 4-1 is the tps which i'll try to test again with a better meter. I think the 5-1 has something to do with the a/c which shouldn't have anything to do with this problem.
Old Oct 31, 2008 | 08:58 PM
want2wheel's Avatar
I hope you get that runner fixed. Let me know if you want me to send you the other TPS. Rob
Old Oct 31, 2008 | 09:04 PM
abecedarian's Avatar
you would get both the 41 and 51 if you ran the engine with the TPS disconnected. disconnect the battery for a few minutes to reset the ECU memory and see if the codes return.
Old Oct 31, 2008 | 10:27 PM
Bill54880's Avatar
Sounds like a dirty or bad i.a.c. That's usually what it is in a 22re when it has idle problems. I just sprayed mine out with throtlebody cleaner and it seems a lot better now.
Old Nov 1, 2008 | 09:00 AM
  #25
99ncxj's Avatar
already unplugged the battery and the codes came back. i've got a tps on the way.
Old Nov 1, 2008 | 09:21 AM
  #26
iamsuperbleeder's Avatar
be sure to read up on installing and proper calibrating before you go and just throw it on there; it can be a little tricky, but's it's rather important.
Old Nov 1, 2008 | 07:54 PM
  #27
99ncxj's Avatar
well, i borrowed a nice Fluke multi meter and tried to calibrate the tps. At first it was giving me very strange readings so i took it off and noticed that it was not returning all the way back to closed position. I sprayed some cleaner in the back and moved it around real good and now it closes nice and quick. Put it back on, set it with multi meter and what do you know... it purrs like a kitten. I guess the tps i bought off ebay will to in the tool box as a spare now.
Old Nov 3, 2008 | 11:49 AM
  #28
99ncxj's Avatar
Update: after setting the tps I bought a timing light to see how bad the timing was off. Well, it was very high. It was sitting about 2" past the end of the marks. I set it to 5deg. with the paper clip installed and when removed it went up to 12. I think its all good now. I drove it about 1 hour today and everything feels good.
and the tps i bought on ebay came in today. guess i'll keep it as a spare.
Old Oct 21, 2012 | 04:04 PM
  #29
red450r's Avatar
Im having these same problems but no CEL
Charecter1
Nov 6, 2023 10:08 AM
GrimWolf
Aug 28, 2015 03:36 AM
PBRaddict#1
Aug 22, 2015 11:34 PM
izzmee
Aug 17, 2015 10:20 AM
Sidherish
Aug 2, 2015 01:42 PM
