Speedometer
Speedometer
I am working on the inoperable speedometer in my 86 4runner.
So far I oiled and checked cable for the inner cable to spin. It checks out.
I checked the speedo and made the needle move with my fingers spinning the speedo assembly in the cluster.
I seem to not be spinning from the Tcase.
This truck had a manual tranny swapped in, itwas originally an automatic.
The transfercase had 4.7 gear installed in it.
Could the Tcase gear install messed something up?
Or is there a silly issue with the tranny swap?
It is a mechanical Speedo setup.
If your sure the speedometer cable isn`t broken, make sure there are no sharp bends in the cable that would cause it not to work. there is always a possibility that the gear in the transfer case is bad or wasn`t installed properly.
Phantez
Sep 30, 2015 08:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Rickstwowheels
Sep 21, 2015 05:21 AM
