Speed sensor (1994 toyota pickup 4x4 22re)
Old Dec 21, 2010 | 09:02 AM
ricoace's Avatar
Hey every body
I am not mechanically inclined at all..I am learning...my speedometer went out...(not registering the speed) I dont see any cable running from the transmission so i can only guess its a speed sensor or something...I actually see two sensor type things attached to the transmission...can somebody tell me which one regulates the speedometer? lol...lh side ...rh side?????
Old Dec 21, 2010 | 10:42 AM
scope103's Avatar
Right side, on the Transfer case (so it is measuring the speed whether you are in 4Hi or 4Lo.) VSS2 is in the transmission.
The part is not cheap, so confirm that 1) the odometer doesn't work either, and 2) Cruise Control doesn't work. Then it's almost certainly VSS1.
http://www.toyotapartszone.com/oem/t...181-35050.html
Old Dec 21, 2010 | 05:11 PM
ricoace's Avatar
Thanks Scope
Its def not working in any gear configuration...this truck has no cruise control installed...The speedometer hasnt functioned in over 4 years...I use this truck for hunting trips. Thank you very much for replying
Old Aug 2, 2016 | 02:12 PM
Clifford1990's Avatar
Would this part work on a 1990 22RE?
It doesn't appear so, judging by the bottom of the webpage.
matrad
Aug 26, 2024 08:21 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
bprice0077
Jun 25, 2015 07:36 AM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
94hiluxZE
Jun 22, 2015 10:42 AM
