Special Service Campaign for 90-95 4Runners, 89-95 Trucks and 93-98 T100s
Old Oct 3, 2010 | 06:17 AM
  #601
norcal93's Avatar
Got my relay rod replaced and the alignment done. It was perfect when I took it in (alignment wise). They dealer gave me the truck back stating that it took so long to do because the tech had trouble aligning it. I drove it home and it veered badly to the right (this is after the work). Took it back a week later when I had the time, and was told that my truck had broken parts, particularly the eccentric bolt. I was pretty angry they gave me a truck back that had broken parts on it. They made good on fixing it, so I can't be too mad, but should not have had to take it back the three times that I did.
That said, the new relay rod is much thicker than the one originally equipped.
Old Nov 1, 2010 | 03:25 PM
  #602
FAST84C10's Avatar
toyota will fix for free
you should get a letter in the mail if you are the registered owner for over a year my truck had 245,000 and they fixed it free funny thing was that was the only part i didnot replace on my front end be cause it looked good to me oh well just take it to toyota and tell them you are in for the steering link recall takes 2 days max
Old Nov 20, 2010 | 10:32 AM
  #603
charley1972's Avatar
Toyota has a website that you can enter your VIN to check and see what recall work has been done.
Old Jan 1, 2011 | 08:51 PM
  #604
TheDean's Avatar
Not to dig up an old thread, but I just bought a 92 xtra cab pickup, after I blew the tranny in my 87 4runna, and I had some downtime at work the other day, so I decided to call Toyota Canada and see what they said bout my new wheels. Turns out, the guy who owned it before me had the campaign done to it last year! Now, time to run the vin on my 89 xtra cab!
Old Jan 1, 2011 | 09:00 PM
  #605
toyota4x4907's Avatar
I just looked mine up... Apparently it hasnt had the recall done yet! Hm... I do need a little front end work, think I'll wait until I get my tax return
Old Jan 1, 2011 | 09:37 PM
  #606
TheDean's Avatar
What website did you use? Or, better question being, how did you look it up?
Old Feb 11, 2011 | 05:38 PM
  #607
Ricky B's Avatar
Simply. Fricken. Amazing----just punched in the VIN for the '91 4Runner. Survey says?
'Please make an appointment with your nearest authorized Toyota dealer as soon as possible'.....
(Hey Detroit, ya listening?....... )
Old Feb 16, 2011 | 05:37 PM
  #608
HappyAdventure's Avatar
http://www.toyota.com/owners/SSCInfo-index.html
Just got mine back today. $0.00 invoice, and they did not try to sell me a thing. Dropped it off last night and they (Ensign Toyota in Logan, UT) gave me a call at about 10 this morning. Can't tell if the alignment is good or not though, it seemed like it was pulling a little, but the wind was blowing hard and snow was starting to come down. I will have to take it for a spin in some less inclement weather.
Old Mar 12, 2011 | 04:44 PM
  #609
Jarhead2147's Avatar
I took my vin into the parts guy at my local Yota dealer and he pulled up my vehicles history and said that my vehicle hadn't had the recall done and to get with the service dept and they would do it. I have a '92 and this is 2011 amazing.
Old Mar 24, 2011 | 03:58 PM
  #610
ZAP Toyota's Avatar
Huh. 94 4runner is in there I really don't wanna have to mess with it though. just won't stop with the wheel turned lmao
Old May 6, 2011 | 12:47 AM
  #611
4Us2Run's Avatar
Drive Shaft or Transfer Case Issue: Possibly $2,500 fix?
Hello to all. We're now proud owners of 95 4Runner SR5, 3.0V6, Auto, 4x4, etc... Was immaculate clean, purchased through dealer. Thank God not a CA original as Fed smog regs mean one O2 sensor vs two here. Found out by "mistake" at dealer it just had the head gasket job at 145K right before we bought it. Previous owner traded it for Tacoma. CarFax did NOT indicate any work had been done nor any problems detected. So much for carfax!
The cat was soon stolen (want to know who repaired it? the place where your pipe dreams come true) so had new larger cat back exhaust installed (welded this time too). I have found a few other problems too. Most important is when I drive between 40-65mph there's a loud deep hum/vibration coming up through gear shift lever. Dealer says my transfer case end bearing has too much play making the drive shaft spin out of balance---wants $over $1k just to remove/inspect. Dealer says transfer case must be replaced as drive shaft has too much play where it connects to transfer case. It turns "out of round" according to dealer.
They also say very loose l/f bearing which may damage spindle. It has some kind of short circuit too. When lights are on, r/r indicator plus brake lamps go completely off when brakes are applied.
Any opinions/advice?
Also, due to my own fault, while trying to clean around air intake I caused a fault code on air temp sensor. Does that mean I need to replace the whole thing or can it be fixed?
Otherwise, if climbing highway offramp & push button to take it out of overdrive, the rpms go up (as expected) but then they drop down as if I'm letting up on gas pedal. Is that a sign of weak fuel pump?
Old May 21, 2011 | 06:30 AM
  #612
iloveboost131's Avatar
yup i heard about this too
Old May 21, 2011 | 07:33 PM
  #613
4Us2Run's Avatar
A visit to an aftermarket shop indicated that the problem is a worn out transfer case yoke. About $300; part costing $125.
Any thoughts?
Old Jul 5, 2011 | 11:51 AM
  #614
havenoclu's Avatar
I just made my appointment at Mark Jacobson Toyota of Durham (NC) for the steering relay rod. They said it would take about an hour. We'll see how it goes...I really need an alignment, so I hope they have no problem including it in the recall. I will report back the outcome.
Old Jul 6, 2011 | 09:56 AM
  #615
havenoclu's Avatar
Well, took them about an hour. They didn't try to sell me anything. Replaced the rod and did a 4 wheel alignment. Awesome!!
Old Aug 12, 2011 | 10:51 PM
  #616
Designman247's Avatar
Engine issue rear 2 cyl will not fire.
1990 Toyota SR5 4x4 with a 22re. Changed out engine, tranny, wiring harness and computer. New engine will only run on front 2 cyl. We've checked spark, compression, fuel, distributor and every thing else I could figure still only the 2 front cyl will fire and only with starting fluid. After it runs on the first 2 cyl1, the plenum for the rear 2cyl is cold. Any help would be great. Thanks
Old Aug 13, 2011 | 07:30 AM
  #617
PAhydrohead's Avatar
Designman,
I hope your question got stuck here by accident. If not, this question needs to be posted in a different thread.
Old Aug 13, 2011 | 08:45 AM
  #618
sc87yota's Avatar
CRAZY! Just called dealership and they told me to "bring it down right now, we have the part and will take care off you" WOW... Lets see how this goes...
Old Aug 13, 2011 | 12:29 PM
  #619
I know it is a Charlie Foxtrot (Cluster F***) in close to converting it to a 22R.
Old Aug 13, 2011 | 03:11 PM
  #620
sc87yota's Avatar
This is great! I just stumbled on this thread this morning... Typed in my VIN to the link above... Found my rig was under recall(code 50N)... Called dealership... and 5 hours later I have my Runner back and cant stop smiling! This is the first time I have dealt with Toyota of Santa Cruz and I was blowin' away by their customer service and prompt work. They didnt say one thing about ALL the modifications I have done(thinking it might void recall??).
The steering relay rod they replaced is way beefier. They also aligned the front end(which I was planning to anyways with my new tires) and replaced a brake pad spring. All I paid was $8. bucks for was the brake pad spring!! This will make me feel much more comfortable on those long road trips with my family.
