The Spagetti that is my hoses are killing me!!!
I rebuilt my engine... a 22rec on a 4runner without cruise control. I attached all of the vaccum hoses that were displayed in the haynes and the 1985 fsm... but still have about 60 percent of the different opening un-hosed. So I am hosed. I looked on roger browns site for pictures and found some, but he has modified and moved things, and most of what is not hooked up correctly is under the plenum and behind the air intake hose. Does anyone have: diagrams, pictures, hose sizes, lists of parts to parts... I'm dying here... I just rebuilt everything and can't figure this out....
Ahhhh...
P.S. My father-in-law(ex-mechanic) and I spent 4 hours just guessing and still ended up with left over openings or wrong size hoses.
One other thing... my banjo bolt going into the fuel system is leaking, anyone know if the washer is the problem and where I would get one... toyota parts at the local dealership was clueless...
Ahhhh...
i'll try and get some pics tonight, here are discriptions of locations...
there is the air valve?... a pass through coming from air intake pipe to the air intake chamber... this one I got figured out...
1. but the two hoses that come off the side of it?
2. there is a hose lead pointing straight up right next to the thermostat...?
3. there is a hose coming out of the front of the plenum going down and to the left?
4. where does the hose coming back from the gas tank hook to?
5. the two hoses coming from the power steering unit hook to...? This one we think we have... but so many of the rig pictures we could find had different set up from here...
6. there is one coming off of the engine directly behind the water pump on the left side of the engine?
That does help with 2 of the hoses... the ones coming from the power steering... I had the second picture already... and all of those are done...
Now I need everything you can't see in any picture anyone has posted ever on every 4runner page I've searched... the bottom left side of the engine hoses.... hahahahahhahahah.....
I'm going a little crazy......
I appreciate the send...
I'll try to get some tonight... that's the second problem... I have it at a friends garage... so I have to bug them everytime I go over... I thought I could have it out last weekend..., but stupid little problems keep creeping up...
LotOMiles
Sep 14, 2015 11:45 PM
