Sound while turning engine
Old Dec 9, 2019 | 07:34 PM
Discodon44's Avatar
Hi all,
Just picked up a 1990 22re pickup, it’s 2wd, 2.4L. 4 speed.
I pulled off the valve cover to check timing chain and adjust valves. When I turn the engine by hand there is a sound and I’m not sure if it is a normal sound. Here is a video
https://youtu.be/-J29FSYgMDI
I appreciate you input!
Old Dec 9, 2019 | 09:24 PM
millball's Avatar
Sounds like compression getting by the piston rings.
All engines make such noise when turned over slowly . More or less.
A compression test is in order to see what cylinder and valve condition really is.
Old Dec 10, 2019 | 07:51 AM
Discodon44's Avatar
Awesome thank you! I will do compression test
Old Dec 10, 2019 | 09:29 AM
FrankTorres's Avatar
The FORCE is strong in that one...
jlewis74
Mar 31, 2012 08:57 AM
adam.dudenhoeffer
Oct 5, 2011 04:45 PM
cederrowe
Jan 13, 2011 08:58 PM
4x4funnerguy
Apr 17, 2009 09:19 PM
Newcomer5
Jun 24, 2008 07:28 AM
