"Something on the truck goes CLUNK CLUNK CLUNK"
Old Jan 23, 2019 | 03:06 PM
ev13wt's Avatar
5 Year Member
Great news!!!
Old Jan 23, 2019 | 03:14 PM
24Tiki's Avatar
Easy to replace. Alexman Video has it on youtube. I have part number on my post.
And you could not hear/feel where it was coming from?
Nice video and beautiful truck too! ^^^ I'll add to my thread.
Cool. In my case, I had a humming sound that sounded like backup vocals for "Living on a Prayer" - LOL!
I verified that wheel did not turn smoothly and one side was louder than the other here
Once I was sure of it, I got MCAX 241 Rear Axle Kit with Koyo bearings from Marlin Crawler:
https://www.yotatech.com/forums/f116.../#post52399536
Perfect! Thank you, I will go to them for the kit. I am pretty sure this is my issue.
Old Jan 23, 2019 | 03:34 PM
akwheeler's Avatar
Originally Posted by akwheeler
Like dropzone said, check for metal in your rear diff, other than that there are some things you could try to give us some more info,
is it different in 4X4? does it change if you swerve side to side? does it change if you hit the brakes?
try removing your rear wheels and brake drums, wiggle your axle shafts up and down as well as in and out to see if you have play in the rear wheel bearings.
make sure you don't have something stuck to the rear wheels or driveshaft.
if you surf back through my build thread "Akwheeler's 95 4runner SAS" you will see pictures of the rear wheel bearing tools I made, might be something you could cobble up. Sorry, I haven't figured out how to attach a link.
Old Jan 24, 2019 | 03:37 PM
24Tiki's Avatar
Good info, I will definitely take a look when I get to doing the job.
One question for those more experienced: Should I consider the possibility of a bent axle? One gentleman in the shop said it looked like my wheel had some wobble to it when I had it on the lift and in drive...could this also just be a symptom of a bad bearing or is the possibility of a bent axle now in the picture? I'm leaning toward bad bearing, given the other symptoms. Just didn't know if anyone else has any experience with this.
Old Jan 25, 2019 | 04:19 AM
  #25
ev13wt's Avatar
5 Year Member
Since it is being held in the diff, if it wobbles both the diff AND the outer wheel bearing need to be "really" bad. On a new bearing, you will have almost the play that we see in the vids above. It is not relevant because there are two bearings in the system.
Pull the axles. It's a 10 minute job. 8 bolts, 2 pins (ebrake) and 2 brake lines. Ok 15m, ya have to remove the rims.
Old Jan 25, 2019 | 05:59 AM
  #26
snippits's Avatar
There is drive train shop not far from me that rebuilds rear ends, balances drive shafts, and etc.. They balanced the drive shaft on my 92 Pickup, and installed u-joints that I supplied for $55 out the door.
When my truck needs new rear wheel bearings/seals, I will pull the axles, and take them to their shop, and let them remove the bearings. Don't think my old body can handle all that beating and banging.
The Marlin Crawler full set is expensive. Has anybody used all Timken bearings and seals?
Don't see the large o-ring rubber seal in the Timken catalog. What does Toyota call it?
Old Jan 25, 2019 | 07:03 AM
  #27
24Tiki's Avatar
Okay, to clarify what you're saying: you're saying I should replace/balance the axles? I'm not opposed since I'll already be in there pulling the bearing. Thank you for the help!
Old Jan 25, 2019 | 07:05 AM
  #28
24Tiki's Avatar
The Marline Crawler set looks like the best deal I've seen so far, especially given they're using mostly Japanese made bearings and seals. I think one set is around 65 bucks?
Old Jan 25, 2019 | 10:00 AM
  #29
snippits's Avatar
Must have been looking at the wrong thing at Marlin. $69 a set is OK with me.
Old Jan 29, 2019 | 12:21 AM
  #30
ev13wt's Avatar
5 Year Member
To have thejm checked for "trueness", I was thinking.
Old Feb 9, 2019 | 06:42 PM
  #31
24Tiki's Avatar
Well, I replaced the rear wheel bearings and got a rebuilt rear third member from East Coast Gear Supply. Really happy with the product and they had great customer service.
The driver's side rear wheel bearing was the source of the clunk sound. When I pulled the bearing and tried to turn it by hand, it was binding at one spot in the 360 degree rotation. It also had a generally coarse and gritty sound when turning by hand.
New question though: I installed the new diff, new bearings, and everything sounds good...until I hit about 45mph. At about 45, I start to get a rear end vibration. Any ideas what it could be? It was not there before, so I know it's something in the rear. Not the diff, not wheel bearings, so right now I'm thinking U-joints, out of balance wheel?
Old Feb 9, 2019 | 07:26 PM
  #32
akwheeler's Avatar
you're on the right track, maybe a wheel weight came off.
get going 50-55 when it is vibrating and kick it into neutral, if the vibration stops right away or changes significantly it is probably the u-joints.
it's easy to wiggle your driveshaft with the wheels blocked and the truck in neutral to check for play in the joints,
by any chance when you did the rear diff work did you pull the rear driveshaft apart at the slip joint?
Old Feb 9, 2019 | 07:36 PM
  #33
24Tiki's Avatar
I made sure to keep the driveshaft connected when I was doing the diff. I bungee corded the shaft the the frame where it wouldn't slip apart. Tomorrow I'll do some more testing and try to pinpoint the issue. Thanks for the quick reply!
Old Feb 10, 2019 | 10:54 AM
  #34
24Tiki's Avatar
Got it up to speed and then went into neutral and the vibration is still there. I want to say it's an out of balance wheel/tire but I can't seem to reason why the issue would surface immediately after doing the rear wheel bearings and diff...I can't make sense of it.
Old Feb 10, 2019 | 11:16 AM
  #35
akwheeler's Avatar
Most likely a wheel weight fell off like I said.
could be that some dirt or something kept one brake drum from fully seating on the axle, could be the axle was bent when the bearings were pressed on, lots of "could be"s
jack up the rear end with the truck in 2wd and let it idle in gear while you watch the wheels/tires for signs of wobble.
Or go have your tires/wheels balanced and see where you are at.
Old Feb 10, 2019 | 11:37 AM
  #36
24Tiki's Avatar
I think I'll get the tires/wheels balanced first. The axles didn't go in a press when I installed the new bearings so I'll put that pretty far down my list I think but if it comes to that I'll do that test.
Old Feb 10, 2019 | 02:32 PM
  #37
24Tiki's Avatar
So I had the wheels balanced and there was little to no improvement in the vibrations (though the tech said the wheels were significantly out of balance). Let me know what you think of this theory: When I pulled the old differential and turned the pinion gear by hand, the old diff turned very easily (due to wear and loosened tolerences). When I got the new diff, I turned it by hand and it took considerably more force to turn. Is it possible that because I swapped the old diff for the new diff, the U-joints are now revealing play due to the increased force required to turn the pinion gear?
This may be a stupid theory but I'm trying to reason through it. The vibrations occur from 45mph and up and also on deceleration. It seems that I can detect a slight, temporary increase in the sound of the vibrations when I accelerate while the truck is decelerating, but then the vibrations normalize.
Old Feb 10, 2019 | 03:49 PM
  #38
dropzone's Avatar
Fossilized
pull the rear driveshaft at the transmission and check for play at your rear output shaft on the transmission
Old Feb 10, 2019 | 04:26 PM
  #39
24Tiki's Avatar
I will take a good look at the driveline components (U joints, center bearing, etc). What might indicate to look specifically at the rear output shaft? Just trying to learn. Thank you
mattr1983
Aug 11, 2013 03:02 PM
Fishaa
Jun 8, 2010 07:49 PM
.faded.fedor.
Apr 2, 2007 08:14 AM
arielb1
25
Aug 4, 2005 04:03 PM
