Someone please ID this undercarriage part for me?
Old Nov 12, 2014 | 05:46 PM
Jerome Horowitz's Avatar
Hangs off the side of the transmission, near the smaller of the two boots in the photo. I suspect it has to do with the clutch as the leaking fluid on the ground appears to be clutch fluid...have a small leak which I would like to get fixed...thanks!
Old Nov 12, 2014 | 06:25 PM
blueknob's Avatar
Clutch slave cylinder, pretty cheap to replace
Old Nov 12, 2014 | 09:38 PM
scope103's Avatar
That's for sure. About $15 at RockAuto. Can't afford to rebuild one at that price.
Old Nov 12, 2014 | 11:36 PM
wyoming9's Avatar
Red face
When doing one may as well do the Master Cylinder and rubber hose as well.
Then it is all done.
Old Nov 13, 2014 | 05:32 AM
Thanks guys for the quick responses. So I presume it is ok to drive with this for the next couple days until I can get to my repair shop. They are going to do an overall checkup since I've only had it for a week. I'll note the slave cylinder and ask them to inspect the master cylinder and hose.
Old Nov 13, 2014 | 01:56 PM
wyoming9's Avatar
Red face
The only thing about driving it and not being able to fix it yourself in a quicky Mart parking lot.
Is if it fails all together your kinda stuck unless your real good a shifting with out a clutch and don`t need to stop.
88sasturbotoy
Jan 30, 2026 01:57 PM
May 20, 2016 10:27 AM
Fundy Rider
Jul 16, 2015 01:35 AM
akaphilly
Jul 9, 2015 02:34 PM
