Somebody please help me before I unload my S&W 45 semiautomatic into my 95 Toyota 4 r
Old Jun 16, 2014 | 12:24 PM
  #61
blueaussie's Avatar
The vacuum line off canister goes, straight to throttle body to throttle instead of TVV.
Old Jun 16, 2014 | 12:54 PM
  #62
Gevo's Avatar
should go to TVV, Without TVV the vacuum is constantly applied to the fuel vapor canister I'm not sure how this will affect the engine performance.
Old Jun 17, 2014 | 05:17 AM
  #63
blueaussie's Avatar
The garage that put the recond engine in did not hook it to the TVV. It was hooked directly to throttle body. So frustrated, thanks Gevo
Old Jun 17, 2014 | 05:29 AM
  #64
blueaussie's Avatar
I looked up what thebTVV was for and it has something to
Do with temperature, maybe this is why it shows running hot but with infared temperature tester it's only around 212 deg f, can someone please chime in? Thanks
Old Jun 17, 2014 | 05:35 AM
  #65
Gevo's Avatar
No, the TVV isn't involved in the cooling system of the vehicle, nor the temperature reporting system.
Here.
http://www.autoshop101.com/forms/h62.pdf
Blueaussie, we don't mind helping, but you should search things before you ask.
Old Jun 17, 2014 | 06:12 AM
  #66
blueaussie's Avatar
Here.
Sorry Gevo, I googled it, I forgot the auto shop link you sent me . Again sorry, most of the time I can google and it refers me to one of the threads here, thanks Gevo
Old Jun 17, 2014 | 08:59 AM
  #67
blueaussie's Avatar
It is so hard to find and read on this iPhone especially since I have CRS disease!
Thanks Gevo
Old Jun 18, 2014 | 03:49 AM
  #68
blueaussie's Avatar
Thanks Gevo
Wow Gevo, your a better Man Than I, I could not find the TVV. I was looking up against the fire wall which is where the vacuum diagram shows it to be located and I could not see a coonection for a vacumm hose. I will try to locate in some of the post on here , I am sure others have gone down this road, Gevo I did manage to break my glasses though...lol thanks Gevo
Old Jun 18, 2014 | 05:47 AM
  #69
Gevo's Avatar
lol. take care of yourself man.
The TVV is hard to see with all of vacuum lines and plenum in the way. I use a little mirror with a collapse-able handle. More than likely the TVV valve is broken, which is why it's not being used. It sits in the same area where all the temp sensors are.
Old Jun 18, 2014 | 06:26 AM
  #70
blueaussie's Avatar
Ahh Haa Gevo wonder why I did not see that sucker. Going to auto parts to get one. Thanks
Old Jun 18, 2014 | 06:37 AM
  #71
Gevo's Avatar
Well, did you see it? You shouldn't have to change it if it is not broken.
Old Jun 18, 2014 | 06:39 AM
  #72
blueaussie's Avatar
No I got to get a mirror to see where it was broke off.
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
nick b
Jul 11, 2015 04:38 AM
Poncho0206
Jul 10, 2015 06:21 PM
