Solid Brass Idler Arm Bushing Kit!!!!!!!!
Old Jan 28, 2009 | 07:28 AM
  #121
BoostinChick's Avatar
Originally Posted by elripster
Actually, I hate to say it but you will almost certainly have to buy a new one.
Here's the problem with old arms. They wear more on the bottom than on the top. This means a bushing that fits properly on the bottom of the shaft just won't fit over the top.
We had considered custom machining but decided against it. There are other issues like shipping costs (customer idlers) and warranty support. When you make one-offs it's very expensive no matter what. If you chose to warranty the part, you are again shipping an idler arm for a second time, making a new set.... etc... Heaven forbid if an idler gets lost in transit... To do custom bushings profitably you'd have to charge a lot of money for them. Or, you simply don't offer a warranty at all. Neither is really an optimal solution.
Frank
So if I were to invest in the Duralast (Autozone) idler arm, could just send it directly to you for you guys to fab me these brass bushings? Or, you guys are still in the "testing" phases.
Old Jan 28, 2009 | 08:09 AM
  #122
elripster's Avatar
We are still in the testing phases but when we are done we'll just stock the bushings.
I wish we could speed up the testing but it just plain takes time to rack up miles.
I'm probably 2 months out of having these in stock, maybe a bit longer.
Frank
Old Jan 28, 2009 | 09:56 AM
  #123
slosurfer's Avatar
Frank
Haha, you aren't kidding. Although since I've regeared I've been driving mine much more. It is pleasant to drive again on the street.
On road, I've been hitting every pothole, dip, and speedbump, to give these an even harder workout on top of just the miles. Offroad, I've been flogging them pretty good.
Old Jan 28, 2009 | 11:27 AM
  #124
BTW, I found this (not sure if it has been posted before). Mo' pictures = mo betta'
http://www.off-road.com/trucks4x4/ar....jsp?id=300937
Old Jan 28, 2009 | 11:43 AM
  #125
slosurfer's Avatar
Just an FYI, I'd be careful in useing the part number from that article or the other article that is floating around, as there are different "stock" idler arms with different ID and OD of the shaft and housing. Otherwise the article is great for the rebuild or when you get bronze bushings to install. When you order them make sure they get the parts for your vehicle, better to tell them your year make and model, and let them find the part number. Also, make sure you get two bushings, I wasn't the only one that had the dealership only order me one bushing. They are only used to replacing the whole arm, not rebuilding them.
Anyways, just an FYI, for those who are rebuilding their idler arms.
Old Jun 17, 2009 | 02:44 PM
  #126
MudHippy's Avatar
Talking
Originally Posted by trbizwiz
Is everybody still happy with these.
Yepper!
Has it been more than 2 years and over 10k miles...already? Wow! Good stuff!
Originally Posted by BoostinChick
I checked the link that the OP posted and didn't see the brass idler arms.
Me neither...but the bushings are still there. You really wouldn't want a brass idler arm anyway.
Ahh...at least 1 thread I can be proud of. SUCCESS!
Check ya later folks!
Old Sep 16, 2011 | 08:03 AM
  #127
pheonix991's Avatar
Hate to bump and old thread, but, how is this holding up for everyone? My stock idler arm needs a rebuild and I'd rather not keep rebuilding it/buying new ones. I have the stock arm if that matters. Should I rebuild it, or get the 5040 arm, and install the brass bushings?
Old Sep 16, 2011 | 08:12 AM
  #128
trbizwiz's Avatar
I sold my truck about a year after doing the mod. While I owned it it was well worth doing. the truck handled much better. I cant say what the longevity was. But it is a better fix than a new arm.
glowz825
Jan 25, 2022 09:28 AM
andrewtexas123
Jul 6, 2016 01:49 AM
kirkrunner
Jul 27, 2015 07:59 PM
andrewtexas123
Jul 23, 2015 11:22 AM
ptb12
Jul 5, 2015 01:49 PM
