So what sort of axles should I be looking at for 400whp
Old Apr 12, 2009 | 02:24 PM
annoyingrob's Avatar
Originally Posted by ocdropzone
How many Supras have you seen with 33"+ size tires on them?
You have a point, but on the other hand, I've seen plenty with drag slicks, and high RPM launches at teh strip.......
I think it's settled though, Dana 60 front, 14bolt rear.
Old Apr 12, 2009 | 03:07 PM
T-1000's Avatar
Ha, those Rockwells weigh over 700 lbs.
Old Apr 12, 2009 | 03:54 PM
iamsuperbleeder's Avatar
with a pair those and 400HP, you'd be right back at the power to wieght ratio of a stock 22re
Old Apr 12, 2009 | 04:00 PM
Matt16's Avatar
Originally Posted by RobD
You mean 4 weeks.
Sounds like we then had a rougher winter in Vancouver. Maybe your weather will grant the Flames the opportunity to brush up on spring lawn bowling.
Old Apr 12, 2009 | 08:38 PM
  #25
"Can't touch a flame when it's.... RED HOT!"
Old Apr 13, 2009 | 06:45 AM
  #26
4runner4ever's Avatar
I drive a 2JZ with turbo and intercooler. Around 350hp and on the road for 2 years now.
I broke attleast 1 diff a year with only a 100hp diesel, some 12-14 total I guess. They all broke due to shock load and torque, not hp.
Since I've swapped the rear for a 9,5 LC axle with locker incl. 4.88 Reider racing gears and the front to a LC hp type (when I did the engine swap) I never had a faillure. That LC rear seems to be indestructable, even with my welding for centering the diff. If I ever need to do a similar swap I would definately go that route again.
Old Apr 13, 2009 | 10:06 PM
  #27
T-1000's Avatar
Where the heck did you get one? I can't find them anywhere.
Do you know what years/models are suitable, because I can't find that either.
Old Apr 13, 2009 | 10:32 PM
  #28
1989toy4wd's Avatar
I read somewhere that the landcruiser 9.5 was actually weaker than an 8in and that there arent a lot of gearing choices with them too!! But I could be wrong!
I would do a 9in in the back, for the front, there is no way to beef it up really!
Old Apr 13, 2009 | 11:20 PM
  #29
Matt16's Avatar
The 9.5" land cruiser diff is definitely stronger. The gear teeth are bigger, the bearings are bigger, the bearing towers are monstrous etc...
Old Apr 14, 2009 | 09:38 AM
  #30
Just luck I guess. Wasn't looking for it.
I can't believe this is weaker than an 8 ". I don't see the point in toyota makeing larger diffs to gain more strenght and than using cheaper materials to cut costs and end up with an inferior diff. Or something similar.
I did a writeup here: https://www.yotatech.com/forums/f88/...le-swap-59132/
Old Apr 17, 2009 | 07:51 PM
  #31
That's an interesting idea. Landcruisers are hard to find around here in the junkyard though.
Old Apr 17, 2009 | 09:21 PM
  #32
KONASTAR's Avatar
hey annoyingrob..
so... if your going with the d60 front & corporate 14 back setup, are you gonna run um' full length?
Mike
Old Apr 18, 2009 | 12:27 AM
  #33
I sure am. Corey's making me a fiberglas bed, I'm going to see if I can get him to make the bed with a 3" flare on it, and buy a matching set of flared front fenders from him.
The D60, and 14bolt are just over 8" wider than toy axles, so with 3" wider fenders on each side, that should cover most of the extra width. The extra inch I may either play around with the wheel offet to compensate, or leave it sticking out.
At any rate, I think it's going to look damn good. At teh very least, it's going to be unique.
Old Apr 18, 2009 | 01:41 AM
  #34
KONASTAR's Avatar
Yeah' i can picture it already! its gonna look sick! haha..
post some pics of it & keep us informed will ya'!
Mike
Old Apr 18, 2009 | 05:08 PM
  #35
oh but of course.
justdifferentials
14
Jun 11, 2017 08:36 PM
dbd6604
Oct 11, 2015 05:30 PM
89hilux1
Sep 14, 2015 06:13 PM
langry345
Sep 14, 2015 03:36 PM
Wardog
Sep 6, 2015 07:57 AM
