slow runner
Old Feb 18, 2009 | 06:19 PM
chevota4.3's Avatar
Angry slow runner
I have a 86 4runner with a 22re and auto trans thats has set for 3 years. I just purchesed it and put plugs, wires, cap and rotor, oil changed in everything, and just put an 02 senser into it. and it still wont get out of its way... this truck is basically stock except for 30 inch tires.. any help would be appreciated.
Old Feb 18, 2009 | 06:46 PM
texcat101's Avatar
4.3's fit nicely
Old Feb 18, 2009 | 06:50 PM
shore.runner's Avatar
As far as I know, the 22re with an auto in it is gutless.
For one, the automatic transmissions on the 3vze (what I have ) doesnt have much punch.
The other thing i can tell you is that since you have 30's on your truck your acceleration, especially uphill is going to be decreased unless you have regeared. The stock gearing of 4.10 is meant for the stock 225 tires and the engine our trucks have arent powerful enough to over look this.
Old Feb 18, 2009 | 07:06 PM
Matt16's Avatar
You could try cleaning the throttle body and changing the air filter, but in reality, the automatic with an 80rwhp engine hauling a 4000lbs truck around is simply going to be gutless no matter what. Having the 30" tires will probably mean that you are frequently overtaken by wildlife on the highway.
Old Feb 19, 2009 | 04:19 AM
chevota4.3's Avatar
it has 4.30 gears in.. and i already have a 79 toy with a 4.3 in it. just want to leave this one alone as much as possible.
Old Feb 19, 2009 | 06:56 AM
son_of_a_lc's Avatar
I would try cleaning the throttle body.
Old Feb 19, 2009 | 07:45 AM
chevota4.3's Avatar
just pulled the upper plenum and throttle body, cleaned everything and its still a turd.. the only thing left is to have my injecters replaced..
Old Feb 19, 2009 | 07:53 AM
fireman1559's Avatar
what i did with my 3.0 was i got my dremel and opend up the throtle body more there was a ring that was almost like a reducer and i ground that smooth and polished it so now its smooth all the way to the butterfly and i can tell a difference at about 35 04 when i floor it it takes off faster
Old Feb 19, 2009 | 08:06 AM
compretion test?
Old Feb 19, 2009 | 08:30 AM
abecedarian's Avatar
4.88 gears, 268 cam, 9.5:1 pistons. That should wake it up a bit. And if the rpm's are too high on the freeway... meh... small price to pay so VW Bus won't pass you.
Old Feb 19, 2009 | 08:55 AM
4banginRunner's Avatar
The tranny is holding you back alot
Here's what i did:
Cat back exhaust 2.25" into a 2.5" Flowmaster 40 series (with a 2.25" tailpipe...having a tail pipe woke it up), Battery/ intake swap, Reargeared to 4.56, and the best thing was swapping in a 5spd
Jun 1, 2021 01:51 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
