Shifter removal
Old Feb 13, 2016 | 08:48 AM
Chris Parker's Avatar
Shifter removal
On my 5 speed transmission, does the black shifter lever separate from the base? I tried twisting it off but it doesn't seem to want to go, I'm afraid of breaking it. I need to get it off so I can heat the bottom part of the lever that's part of the shift tower so I can move the shifter position slightly.
Thanks
Old Feb 13, 2016 | 09:25 AM
MudHippy's Avatar
No. You need to pull the boot off, then release the collar(push down and left) holding it in there. Then it pulls right out.
Old Feb 13, 2016 | 08:45 PM
Ok that sucks, I'm afraid heating the lower shaft will burn up the rubber insert at the bottom of the upper part of the shifter
Old Feb 14, 2016 | 01:15 AM
dropzone's Avatar
Fossilized
Originally Posted by dropzone
Poor Man's shift lever retainer removal tool:
here is a pic out of the manual that shows the SST:
since i had the idea of using an old socket or some tubing I thought I would give it a shot. 6 minutes with the grinder I had this:
1" square tubing, notched and bent in slightly to fit in the shifter retainer
slip it over the shift lever
use your tool of choice, push down and turn to the left about a 1/4 turn
bingo:
Davebarbier
Mar 27, 2016 04:04 PM
tomanator
Feb 21, 2016 02:22 AM
Mhkabler95
Feb 12, 2016 10:06 PM
kheinz01
Feb 8, 2016 01:59 PM
BUDD
Feb 8, 2016 12:53 AM
