Shakes and Hesitates
Old Sep 7, 2006 | 02:08 PM
Tempeboy's Avatar
Hello all, I have a '91 4runner SR5 V6 3.0 3VZE, it has recently begun to shake and hesitate when I accelerate, it shifts smoothly but when I get up to around 45mph thats when it is very noticeable, it feels like it wants to "bogg" down. If I continue to accelerate it will-after some hesitation- get around 60 mph and the shaking ( not referring to an alignment type shaking) from the engine will slightly smooth out. Any ideas on what could be going on. I aplologize if it's not to descriptive but if you need to know more please let me know. I'm thinking my first step would be to get the spark plugs and cables changed out.....
Old Sep 7, 2006 | 02:13 PM
taikowaza's Avatar
2nd gen tuning
start with the usual culprits.
-change wires
-change spark plugs
-change rotor
-seafoam it! (I like to go overkill-one bottle in the crankcase after an oilchange, one bottle in the gas tank, and suck a bottle into the brakeline).
-have your injectors pulled and cleaned professionally by Dr. Injector or similar.
-change your oil and all fluids
has worked wonders for me! (along with new exhaust and headers...great!)
Old Sep 7, 2006 | 09:05 PM
Tempeboy's Avatar
Thanks
Will definetly do that, I will post the results this weekend
I take it that this is a common problem or one that you have heard of? Once again thank you!
Old Sep 8, 2006 | 03:48 AM
yodaLJ's Avatar
to me it seems like a fuel problem... maybe its not getting enough fuel due to a clogged fuel filter for when the rpms suddenly jump... thats just me tho.. it could be in the wires or coil tho
Old Sep 12, 2006 | 12:56 AM
Tempeboy's Avatar
Fixed
I had the spark plugs and cable changed out and the problem was gone, I will still get my injectors pulled and cleaned, but problem solved Thanks for the help
calderp
Nov 16, 2015 02:49 AM
BK2TFUTURE
Oct 11, 2015 08:42 PM
shredder4286
Oct 1, 2015 01:09 PM
sanctfy
Sep 13, 2015 06:33 PM
Boomer8404
Sep 10, 2015 09:01 AM
