Sensor ID on 1990 3.0 5spd
Old Jan 27, 2009 | 07:03 PM
axledeep's Avatar
This one has been driving me crazy. As many of you know, there is a bank of sensors between the intake plenum and firewall on the 3.0. I am trying to ID a few of the sensors, as my setup does not look exactly like all the pics I've seen nor the FSM. I know these sensors are arranged differently depending on year and possibly also depending on auto vs. manual tranny. Mine is a 1990, 3.0, 5spd.
I've attached a pic. Starting from the sensor on right (green plug) - can anyone positively ID these sensors for me.
GREEN on right = Engine Coolant Temp. Sensor for ECU?
BLACK to the left of green = ? (depending on what I read, it is either the Cold Start Switch or some mysterious "Water Temp. Sensor")
YELLOW = temp sender for gauge cluster?
Is this right?
Thanks!
Old Jan 27, 2009 | 09:03 PM
JonnyBoy's Avatar
From left to right:
SWITCH, WATER TEMPERATURE (FOR E.F.I) Toy part no 89428‑14070
SWITCH, START INJECTOR TIME Toy part no 89462‑20040
SENSOR, WATER TEMPERATURE (FOR E.F.I.) Toy part no 89422‑20010
Old Jan 28, 2009 | 05:29 AM
axledeep's Avatar
Thanks so much! Two more questions...
The YELLOW Switch on far left, 89428‑14070. Is this what sends signal to the dash gauge, typically referred to as the Temp. Sender? Does it have any other purpose (ie does it send any signal to ECU or can it actually affect how the motor operates)?
The GREEN Sensor on far right, 89422‑20010. Is this what tells the ECU what the coolant temperature is at?
I'm trying to narrow down a coolant temperature based idle issue. Thanks for your help!
Old Jan 28, 2009 | 11:36 AM
JonnyBoy's Avatar
I'm pretty sure the yellow and black ones, since they're switches, not sensors, control the efi, and the green is the gauge sensor.
I could be wrong, but the terminology used leads me to believe I'm right.
Old Jan 28, 2009 | 01:00 PM
axledeep's Avatar
Hmmm, well...I'll keep digging then. Do you have an FSM for the 90 that has these sensors located the same as in my pic? I have an FSM that I thought was for my 90, but the sensors are laid out differently than what is in the book.
Old Jan 28, 2009 | 07:28 PM
JonnyBoy's Avatar
http://www.toyodiy.com/parts/p_U_199...MGEA_8404.html
There's where I referenced it.
theking11863
Mar 19, 2016 09:36 PM
Gone Fission
Jul 24, 2015 12:49 PM
jackiebrownia
Jul 20, 2015 09:02 AM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
ptb12
Jul 5, 2015 01:49 PM
