Seating Options
Old Nov 15, 2011 | 03:40 PM
Teuf's Avatar
Did you remove the rug to check?
Old Nov 15, 2011 | 11:10 PM
yotarover's Avatar
yep i've had it out and there's only 4 holes.
Old Nov 17, 2011 | 01:03 AM
yotarover's Avatar
po had it all welded shut go figure? i couldn't drill & tap
Old Nov 17, 2011 | 01:19 PM
Teuf's Avatar
The weld metal should be drill/able. Give it a shot.
Old Nov 17, 2011 | 06:31 PM
  #25
gottadog's Avatar
I went with 95 sr5 runner seats. they are super comfortable. On my 87 I pulled the carpet back and there were 2 hidden holes with the welded on square nuts, the carpet backing has the circles marked and somewhat cut. I used an exacto knife, and I mean a pretty old dull blade and it just popped em out easy. With these seats I had to grind the front inner holes on the seats and push moderately hard to get the rear to line up. Its very close in the back. If you go this route get the seats ready and able to mount all 4 bolts, then put the rear bolts in first, I noticed the front bend in slightly. I also used the front seat belts from the runner, so I have the hard plastic over the belt. Much nicer then the floppy buckle
Old Nov 18, 2011 | 06:17 AM
  #26
yotarover's Avatar
i switched in some runner buckets. a lil bit of force and holding and they lined up on all 4 after i redrilled the holes. now i gotta go tackle the freaking rust on drivers side floor board before it gets worse. removed the plastic liner to see a hole there .
Old Nov 18, 2011 | 10:26 AM
  #27
N2Frodn's Avatar
Zombie thread springs back to life.
Anyway, The mounting locations for buckets in trucks that came with a bench are (in my experience not drilled, backed up with weld nuts or marked.
Tacomas are marked, no backing nut though.
Pretty easy, just put the seat in, mark the other holes, drill and put a nut and bolt in.
2 out of my 3 trucks had bench seats, all now have buckets.
2000 tacoma buckets in my 96
1st gen 4runner buckets in my 86
Lexus power seats in my 87 (Not a bolt in swap).
ETA: Tip. Most toyota bucket seats have identical bases and backs (the upholstered parts) from driver to passenger. Meaning that if you find two trucks (say in a junkyard) with the identical interiors and both have thrashed drivers seats but the passenger seats are good, you can grab the seat base and back from a clean passenger seat, swap it into the drivers side frame and make a good pair of seats.
I have also swapped them on my trucks after a few years to even out the wear.
Old Nov 18, 2011 | 11:21 AM
  #28
tj884Rdlx's Avatar
Originally Posted by 1986 4 Runner
Looking to Replace my seats in my 86 runner...
what model car or truck seats convert the best... I have a welder and all that good stuff so customizing is not a problem... was thinking of 3rd generation 4runner seating and converting so I have all matching stuff....has anyone had any luck with this??
fyi: just saw an ad on atlanta craigslist, guy's selling some 22re parts including grey TURBO seats. there's a picture of em.
argh. replying to zombie thread from a year ago.
but if ANYONE ELSE wants turbo seats, go check it out.
Old Nov 18, 2011 | 10:50 PM
  #29
Turd Furgeson's Avatar
I found a set of almost mint seats out of an older mr2 at the junkyard that fit well after a little modification and was happy with them.
Old Nov 19, 2011 | 01:45 AM
  #30
yotarover's Avatar
it puzzled me why there were only 4 holes. then their should have been at least 8. thats when i looked i saw weld spatter. but yeah it's a old thread no point in making another thread about seats.
Ryansenior16
Sep 22, 2015 05:24 PM
sonorn67
Sep 19, 2015 05:39 PM
longbed
Sep 16, 2015 10:35 AM
ac7822
Sep 12, 2015 06:57 PM
Badfish740
Sep 4, 2015 04:21 AM
