sealant on top bolt of oil pump 22RE
Old Apr 17, 2016 | 05:41 AM
ditypup's Avatar
Hi guys - My oil pump has a leak between the pump body and the timing cover, pooling right at the bottom center. It is not the front seal. I think it is because I didn't put sealant on the top bolt. Going to take the pump off today.
My question is. Do you all use Loctite 271 (red) or Permatex red threadlocker?
Seems to me that that would make the top bolt a real bugger to remove in the future. Wouldn't Loctite blue suffice?
What have you'all used successfully? thanks
Old Apr 17, 2016 | 08:06 AM
rustypigeon's Avatar
Use a thread sealer, not a thread locker.
I use Permatex High Temperature Thread Sealant #59214.
Old Apr 17, 2016 | 01:26 PM
an1176's Avatar
I believe the is an O ring around the oil pump housing. Those get brittle and flat and start to leak over time.
MudWaspSR5
Mar 8, 2016 03:11 PM
Blissard
Mar 3, 2016 09:17 PM
Brendan
Feb 28, 2016 08:06 AM
BK2TFUTURE
Feb 9, 2016 09:45 AM
litletre
11
Jan 29, 2016 08:29 AM
