Seal packing on cam bearing caps 1 & 5
Old Aug 13, 2010 | 05:33 AM
Andy A's Avatar
Question on applying the seal packing to the cam bearing caps. The FSM shows it like below.
On cap #5 the FSM shows a continuous bead on each side but the groove cut into the cap is not continuous. Also there are 2 small grooves around the bolt holes that shows no seal packing there.
On cap #1 the FSM shows a dab of sealant on the corner edge and not the grooves cut into the cap.
or does the sealant only go in all the grooves cut into the cam bearing caps
Old Aug 13, 2010 | 07:04 AM
snobdds's Avatar
If it was me, I would only put FIPG in the grooves. I would not want that stuff seeping out onto the cams...
Old Aug 13, 2010 | 09:42 AM
Tubbyfatty's Avatar
Yes, only put RTV in the grooves. Dont go too light on it, make sure theres a LITTLE extra in there.
Put some on the outside of the cam seals too, make sure to put oil on the inside of the seal so it doesnt burn out when you start it.
Toyota FIPG is permatex RTV by the way, its the same stuff. .
Old Aug 13, 2010 | 07:19 PM
Andy A's Avatar
Thanks will do the grooves only.
Old Aug 13, 2010 | 08:07 PM
Tubbyfatty's Avatar
It doesnt matter if some gets on to the bolts or down the holes.
Old Aug 13, 2010 | 08:20 PM
Andy A's Avatar
Will be so happy to get this truck back up and running. Has been a long slow process.
Old Aug 12, 2016 | 09:56 AM
supraman1's Avatar
re: '89 4Runner 3vze camshaft bearing caps sealant
Sure takes a while to find some of this info. The bearing cap sealant is like hard plastic on my caps and head as shown in the attached pictures. Maybe this happens after 273K miles. Some of it just broke out. The manual is sometimes hard to decipher or believe when you have something that conflicts with what you're seeing. Thanks for the post regardless of how old it is. (well yeah, I haven't done that much of this type of work but I'm doing it)
Old Aug 12, 2016 | 12:41 PM
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
Are you asking what to do? Yes, take a sharp and pick that hard stuff out. Careful not to scratch surface (my thoughts). Hardened way before 200k.
bigjstang
Jun 2, 2025 03:56 PM
smthwsn357
May 1, 2024 07:28 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
mskalmus
May 28, 2017 07:51 AM
yourrealdad
Jul 21, 2015 11:13 AM
