same 22-re...new codes
Old Sep 23, 2006 | 06:51 AM
toyotamanxxx's Avatar
well im sure this has been coverd before......
i have code (24) - intake air temp sensor
???? where do i find it at on this motor ???? and can i test it ???
also have code (31) - volume air flow meter problem
can i do a test on it or do i have to just buy new stuff????
thanks for all.....
Old Sep 25, 2006 | 12:13 PM
Wrench's Avatar
I just cleared my code 24 it was my knock sensor cable that got chewed up. The sensor is located next to the fuel filter.
Hope this helps.
Old Sep 26, 2006 | 04:33 AM
Flash319's Avatar
Intake air temp sensor is in with the AFM. Check your connection to the AFM. If connector is fine then you need a new one.
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
