runner vs. pickup
Old Nov 20, 2009 | 11:05 AM
peow130's Avatar
dang i need to advance my timing now, too >.>
Old Dec 1, 2009 | 06:50 AM
buckshot1224's Avatar
ok, I've been reading a good bit and I've still got a question...........
In order to advance the timing do you change it with the distributor or the actual timing belt? I'm still not completely understanding this. I see there are some down falls with over heating and lean motors but what else.
I'm a picture guy if someone can point me to some pictures to explain.
Old Dec 1, 2009 | 07:36 AM
JollyGreen's Avatar
twist the distributor
Old Dec 1, 2009 | 08:03 AM
misterzee's Avatar
Originally Posted by Matt90V6SR5
What are the pros and cons of advancing the timing? please splain
Originally Posted by 874runnersr5
pros- a bit more power
cons-might have to run higher octane and need a timing light.
Also it will tend to be a little "jerkier" on the gas pedal, and your emissions will change, NOx will go up.
Old Dec 10, 2009 | 05:27 AM
  #25
Alrighty guys..........
We set the timing back and it may have changed it a hair but not that much.........
So, we decided that that isn't the source of all this power.
I was wandering, what upgrades can be done to the cams on these engines that could cause this? We thought this motor was completely stock but not so sure anymore.
Old Dec 10, 2009 | 06:11 AM
  #26
cusportsman's Avatar
I bought this truck and it has definitely got some power. Accelerated in 5th up hills on the interstate running 75.
What is the need for the timing light and where would you install it? Next tank of gas I'm going to run high octane and see if that corrects the lean code.
Might turn the timing back just a hair.
Old Dec 10, 2009 | 10:45 AM
  #27
Ezrider_92356's Avatar
a timing light is a tool that is used to set the ignition timing.
Dylan199119
Jun 25, 2015 09:54 PM
Outsane
Jun 24, 2015 05:52 PM
stanz
7
Jun 24, 2015 12:04 PM
zytra
Jun 24, 2015 08:14 AM
infinityisfive
Jun 16, 2015 06:51 PM
