RPM jump with steady increase in throttle
Old Oct 24, 2009 | 02:24 PM
sv-tex's Avatar
Exclamation RPM jump with steady increase in throttle
I have a '90 Pickup, V6, 4x4, manual trans. When i press the accelerator slowy from idle the RPMs get up to around 1500 and then immediately jump to near full throttle. What could be casuing this? TPS? Throttle body? Vacuum? I have been searching and cannot find anything on this. Thanks.
Old Oct 24, 2009 | 02:26 PM
Kiroshu's Avatar
sounds like tps to me.... any codes?
Old Oct 24, 2009 | 03:29 PM
ski187's Avatar
Sounds like your clutch is gone, the same thing happened to me. One day it worked then the next day i was going skiing and the rpm's shot through the roof when i hit the gas. There was a little resistance at first then the rpm's climb up.
Old Oct 24, 2009 | 03:32 PM
Kiroshu's Avatar
Wow i didn't thnik about clutch slipage..... that is indeed possible. Are you drving down the road or taking off and all of the sudden you stop moving but ur motor is reving? thus may be time for a clutch.
Old Oct 24, 2009 | 04:12 PM
sv-tex's Avatar
it happens even in neutral. sitting still, slowly pushing the accelerator and then bam, the RPMs just go way up. no slipping of the clutch, although i'm sure it is pretty worn (like everything on this truck)
Old Oct 24, 2009 | 04:15 PM
Kiroshu's Avatar
yea i'd say tps...... does it have any codes?
Blamalam
Mar 12, 2022 07:34 AM
utahman
Aug 23, 2015 02:04 PM
mtc1105
Aug 4, 2015 08:06 PM
altydog
Jul 28, 2015 10:20 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
