Rough idle on first Toyota: '87 4x4 22r /w Weber Carb
Old Jul 21, 2012 | 01:24 AM
ilovelivinginthecity's Avatar
Question Rough idle on first Toyota: '87 4x4 22r /w Weber Carb
Old Jul 21, 2012 | 06:01 PM
slow-mo's Avatar
First off, very nice looking truck. And welcome to Yotatech.
Originally Posted by ilovelivinginthecity
It's got a Weber carb in it.
I won't be able to help you as I have the Aisan carburetor. But there are many here that are familiar with them. Here's a thread on the Weber carburetor over in forum 115.
https://www.yotatech.com/forums/f115...b-info-241818/
There's an oil leak coming from somewhere below the valve cover gasket. You can see a bit of the gunk splattered up from it in the top image. Any ideas?
Two possibilities. The valve cover gasket itself. Or there are two rubber half-moon shape gaskets that fit under the valve cover. One in the very front and one in the very back. The front one may have lost it's sealing abilities. The valve cover sits on top of them.
Part number 11183 in the parts fiche link below.
http://www.utoyot8.com/FullImage.asp...-++++%2922R%23
Old Jul 21, 2012 | 06:11 PM
bone collector's Avatar
nice truck!! and welcome to yotatech. Since the truck has been sitting awhile i would pour a can of seafoam treatment down the tank, another down the oil case after you change it and a 3rd can slowly down the brake booster hose as the truck is idling. this should help clean out the fuel lines, engine gunk and vacuum hoses. I do it to all my trucks and the stuff is amazing. good luck!!
Old Jul 22, 2012 | 01:15 AM
Old Jul 22, 2012 | 03:23 AM
Old Jul 22, 2012 | 04:22 AM
drive it for a week to see how it is. then to a full tune up on it(all filters, plugs, oil, tranny oil, diff oil, grease everything etc.) that way you know when and that its been done. then i would do the seafoam stuff. good luck!
Old Aug 19, 2012 | 08:25 PM
Weber Woes
Old Aug 26, 2012 | 11:48 PM
Old Aug 31, 2012 | 02:11 AM
Old Sep 3, 2012 | 06:11 PM
Old Dec 31, 2012 | 04:22 PM
ByTheCreed0416's Avatar
Same Problem
So after you did all this did you fix the other problem & what was causing it because I am having the exact same problem.
Old Jan 1, 2013 | 08:09 AM
87yo_ta's Avatar
The thread mentioned several problems. What problem are you having? Fouling plugs, vacuum leak, etc?
Old Mar 20, 2013 | 03:46 AM
catfish21's Avatar
Will vacuum leaks cause hesitation in idle because my damn weber is leaking at the base to. And run non ethonal gas if u can I hear this helps
Old Mar 20, 2013 | 04:17 AM
nightstalker's Avatar
The 38 is to much for a stock 22r, the 32/36 was a much better choice, not saying it wont work, (38)but definatly cause crappy gas mileage. If ur gonna keep the 38, prob have to jet it down and then settle for worse gas mileage, or you could throw cam, header and decent exhaust on so your not down shifting at every hill you come too
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
the_supernerd
Oct 1, 2015 09:20 PM
kawazx636
Sep 29, 2015 08:22 AM
Toys4parts
Sep 26, 2015 01:56 PM
taraf
Sep 25, 2015 02:57 PM
