Rough Country Lift Questions
Old Mar 23, 2009 | 02:27 PM
RoBatt's Avatar
heres a pic ill get better ones later
the rear sags about an inch so im gonna put a 1 inch coil spacer in there to fix it
Old Mar 24, 2009 | 12:58 PM
yoder519's Avatar
thats a good lookin runner. how bad do them tires rub? i bet its slow now on stock gears.. i know mine is
Old Mar 24, 2009 | 02:12 PM
Junkers88's Avatar
Man that thing looks tough! Nice rig!!
Old Mar 24, 2009 | 03:02 PM
RoBatt's Avatar
Its actually not that bad with stock gearing i can hold 70 up a hill in 4th gear if i wanted to but the only thing i have a problem with is gas mileage but i expected it... i dont know what all the hype was about it being slow... eh well
yeah the front tires rub on the black plastic bumper (whatever its called) below the turn signals but thats an easy fix its not to bad and i dont know about the pinch weld yet...
the rear rubbed pretty dang bad in the back of the fender when i flexed it so i took the mud flaps off and i think it will do the trick im also gonna lift the rear about an inch to level it out so the rear shouldn't be a problem after i install the spacers
Thanks man i appreciate it
Old Apr 9, 2009 | 11:06 AM
  #25
Booosted Supra's Avatar
when you install the spacers can you take more pics of your rear end set up? right now im thinking about going with the same lift but still using the 2 inch coil spacers and front bj spacers that i currently have on my truck to give it a little more 6 inch in the rear 5.5 in the front, any pics would be greatly appreciated
Also can you snap a pic of the side of the truck when you add the spacer and your driveshaft angle?
Old Apr 9, 2009 | 11:22 AM
  #26
mt_goat's Avatar
Originally Posted by abecedarian
...didn't show you this yet either...:
Yeah those Pro Comp kickers are sweet.
Old Apr 18, 2009 | 10:01 AM
  #27
RoBatt's Avatar
Here are the before and after pics
before
after
kinda hard to tell but the difference when its infront of you is very noticable
herea re the spacers i got off of trdparts4u.com
Sleaker
Aug 26, 2020 06:03 AM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
skoti89
Jul 6, 2015 07:45 PM
