Rotating crank and cleaning pistons
Old Jul 14, 2006 | 11:57 AM
bsanders30096's Avatar
Question Rotating crank and cleaning pistons
95 4Runner SR5 185k.
I'm just about to put my newly machined heads back on the motor, but I want to finish cleaning up the remaining pistons (that are currently not at TDC). The manual I have says to rotate the crank until each piston reaches TDC, and when it does, clean it. This is not a problem, but I'm wondering if I have to rotate the crank a full 2 revolutions to bring it back to TDC of the compression stroke. This is what I'm assuming. Is this correct? Are there any other things that I have to do/take note of when rotating the crank without the heads on? What is really good for cleaning the carbon off these pistons?
Thanks in advance, Brian
Old Jul 14, 2006 | 12:16 PM
Ganoid's Avatar
TDC is not only the position of the #1 piston but more importantly its the relationship of the cams and distributor to the #1 piston. Just as long as #1 is at TDC you are fine just make sure the cams and dist go back in properly. The 2 rotations of the crank to one rotation of the cams thing only applies when you actually have cams and a dist in the motor with no cam or dist in the motor yet TDC is just TDC nothing more.
Old Jul 14, 2006 | 12:42 PM
That's what I thought, just wanted to make sure. Thanks again!
bigjstang
Jun 2, 2025 03:56 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
ShakinIt2x
Jul 21, 2015 06:20 PM
CanRunner
Jul 20, 2015 01:29 PM
