Roll bar, take it or leave it?
#65
Thanks. I was thinking about taking them off for a while but I think I will keep them to run with the whole old school theme. I just wished they looked as good in real life up close.
#67
well it was fun reading everything and almost everyone had a good point.
but overall answer is take it off. it makes your truck look way better. the role bar would look better if your truck had rust everywhere.
#68
THe roll bar will be going back in, I can't deny it
My inner redneck/child loves it way to much.
Reapers setup is awsume! I could amagin mine like that, with my hi-life tucked in to the side
I dont know how my 33x12.50" super swamper spare would fit like that
My inner redneck/child loves it way to much.Reapers setup is awsume! I could amagin mine like that, with my hi-life tucked in to the side
#72
dood.. put the redneck bar back in there.. how are a bunch of drunk hillbilly's gonna hold on when your shmobbin the backwoods? i vote leave it in, paint it orange, and put beer stickers all over it.
lol jk.. looks good either way.
#74
i also say LEAVE IT OFF. those types of roll bars don't really do that much in a 'real' rollover because they are attached to sheet metal. they might protect a little bit, but not enough to justify taking up that much space as well as looking straight up 80's style.
Now you can argure that the seat belt save his life and i wont disagree with you there at all. But if you also take into account the every window in the truck was broken except the rear slider you might think a little different. Then if you were to look at the rest of the carnage, like how the entire roof of his truck was smashed except for an area about 10 to 12 inches from the dual tube roll bar forward. The entire area of the roof in both the driver and passenger area of where your head would be was only mildy damaged with no evidence of crushing. So yes..the seat belt kept his head from going forward into the destruction zone...but the roll bar kept the rest of his head intact.
The following day the wrecker dropped off what was left of his truck in his yard and upon further inspection we found:
Only 2 more bolts remained unsheared that held the roll bar in.
On the driver side of the roll bar where the double tubes made their bend to connect the top bars to the down bars to form the hoop was the point of initial impact flattening out the corner but the roll bar held its strength intregrity.
The roll bar was not tied to the frame only bolted thru the box with steel plates on the underside of the box sandwiching the roll bar mounts between the box floor.
So you be the judge did the roll bar play a part in saving his life? I belive so. But I also belive if he hadnt been wearing his seatbelt he be dead too. It was both devices working in unison that did it. But without one or the other there could have been a completely different outcome.
But I do also know that if not bolted correctly or just hap-hazardly thru the box it will most likely fail before it can save your life. But some protection is better than no protection.
#75
#77
Mine too. I wouldn't run one of th flimsy slide together and pin in place bars! They look cheap and don't have the same potential as the solid tube units. Though I hope to never need mine for anything other than supporting lights and tieing stuff too. The bar makes a GREAT place to hook my straps when I load my motorcycle into the truck. . .
A SUPER OLD pic!
A SUPER OLD pic!
#78
#79
Go for the light bar!
Hell, I can't even find a half decent Roll Bar for my 93 'Yota. Everyone around where I live quit manufacturing them due to the fact that on of our main steel plants closed down.
So yeah, go for it!
So yeah, go for it!
