Rod bearing question
Pirate - I think a little bit of movement in that direction is fine, especially on worn bearings. Are you thinking of replacing them? There are specs for the crank on movement in that direction, I guess it tells you if you need new thrust washers or something, but as far as I know, there is no "thrust" measurement for the rods. If that is your block and you have it down that far, sure would be easy to throw new bearings in there.
Sep 4, 2015 09:27 AM
cgilley
Jul 25, 2015 10:55 PM
