Rims corroded to spindle. Possible options for removal?
i think he is saying that the rims are stuck
if so, two ideas i 'borrowed' from some canadian posters on another board:
1) heat: apply heat to the rotor/drum
. it will expand at a different rate than the alloy wheel, the rust formed between the alloy and the iron will break loose eventually.
2) pressure: use a 2x4 and a jack against the frame/anything solid on the truck. watch out because when it breaks loose it will really break loose - you may want keep a few lugs on just in case
btw, you still owe me a PM on all that stuff i want to buy off said truck. good luck
. it will expand at a different rate than the alloy wheel, the rust formed between the alloy and the iron will break loose eventually.2) pressure: use a 2x4 and a jack against the frame/anything solid on the truck. watch out because when it breaks loose it will really break loose - you may want keep a few lugs on just in case
Yeah, sorry I just got back from florida I will pm you when I get back. I got a pic of that console for you.
Taco I'm not hitting it like your girlfriend wants me to hit her from behind..
The rim is seized on. I tried prying it with a 2x4 and busted it in half. Mabe I will try a highlift jack and chains.
put the wheels pointing straight ahead then extend two bottle jacks horizontal, between the rim and frame, and blocks of wood between the jacks and the rim, and equally apply force to the jacks a bit at a time while someone else rocks the steering wheel
#25
i had stuck wheel befor beat the liven piss out of it never came off
so i got oh the bob cat rammed it wiht eh bucket and pop off it came
other time we had stuck whel i just chained the one well on to my yard car got upt t liek 30 k and pop off it came
so it does happen i only had 2 were hammer just does not work
#33
#39
Step 1) get one of these
Step 2) Attatch one end to said stuck wheel
Step 3) Find her:
Step 4) Attach the other end of the chain to her
Step 5) Run out in front of her and then away from your truck with a cup-cake in your hand
That wheel is bound to come off
Step 3) Find her:
#40
