Rims corroded to spindle. Possible options for removal?
Old Jan 17, 2010 | 09:02 PM
alfio's Avatar
i think he is saying that the rims are stuck
if so, two ideas i 'borrowed' from some canadian posters on another board:
1) heat: apply heat to the rotor/drum . it will expand at a different rate than the alloy wheel, the rust formed between the alloy and the iron will break loose eventually.
2) pressure: use a 2x4 and a jack against the frame/anything solid on the truck. watch out because when it breaks loose it will really break loose - you may want keep a few lugs on just in case
btw, you still owe me a PM on all that stuff i want to buy off said truck. good luck
Old Jan 17, 2010 | 09:29 PM
JigsN Rigs's Avatar
Yeah, sorry I just got back from florida I will pm you when I get back. I got a pic of that console for you.
Taco I'm not hitting it like your girlfriend wants me to hit her from behind..
The rim is seized on. I tried prying it with a 2x4 and busted it in half. Mabe I will try a highlift jack and chains.
Old Jan 17, 2010 | 09:53 PM
Tbeck792's Avatar
Do you want to save the rim at this point or is a grinder/ torch worth it?
Old Jan 17, 2010 | 10:05 PM
abecedarian's Avatar
put the wheels pointing straight ahead then extend two bottle jacks horizontal, between the rim and frame, and blocks of wood between the jacks and the rim, and equally apply force to the jacks a bit at a time while someone else rocks the steering wheel
Old Jan 17, 2010 | 10:31 PM
  #25
Nashman00's Avatar
i had stuck wheel befor beat the liven piss out of it never came off
so i got oh the bob cat rammed it wiht eh bucket and pop off it came
other time we had stuck whel i just chained the one well on to my yard car got upt t liek 30 k and pop off it came
so it does happen i only had 2 were hammer just does not work
Old Jan 17, 2010 | 11:04 PM
  #26
Tbeck792's Avatar
i was thinkin about a tow strap and another truck but decided that was a bad idea.
Old Jan 17, 2010 | 11:09 PM
  #27
peow130's Avatar
Perhaps you could use a bottlejack, like said before...
Old Jan 17, 2010 | 11:25 PM
  #28
JigsN Rigs's Avatar
Yeah I think I might try that tomorrow..
Thanks guys
Old Jan 17, 2010 | 11:42 PM
  #29
well, it is tomorrow... even in WI.
Old Jan 18, 2010 | 12:15 AM
  #30
g_cali's Avatar
That's what i would do.
Just make sure your all clear an go for it!
Old Jan 18, 2010 | 12:24 AM
  #31
JigsN Rigs's Avatar
Yeah its tomorrow for you. Tomorrow for me starts when I get off work here at 6 am
Old Jan 18, 2010 | 03:59 AM
  #32
JigsN Rigs's Avatar
Just tried the pry bar and the sdledge again with no luck. I guess this afternoon I will try and get a blow torch
Old Jan 18, 2010 | 09:32 AM
  #33
ilostmypants's Avatar
make yourself one of these.
http://www.freepatentsonline.com/6012211.html
Old Jan 18, 2010 | 11:37 AM
  #34
JigsN Rigs's Avatar
i would so make one of those if i had the tools to do it.. can i buy one anywhere
Old Jan 18, 2010 | 01:34 PM
  #35
Albert.G's Avatar
I think its SAS time if it doesn't come off
Old Jan 18, 2010 | 02:19 PM
  #36
DupermanDave's Avatar
Can you put a jack sideways on the inside of the IFS and jack it "up" to try and get it to push the rim off?
Old Jan 18, 2010 | 04:41 PM
  #37
JigsN Rigs's Avatar
how can i go sas if i cant get the tires off... i wont be able to get ifs off
Old Jan 18, 2010 | 06:17 PM
  #38
Albert.G's Avatar
oh but you really can torch it off
Old Jan 18, 2010 | 06:44 PM
  #39
iamsuperbleeder's Avatar
Step 1) get one of these
Step 2) Attatch one end to said stuck wheel
Step 3) Find her:
Step 4) Attach the other end of the chain to her
Step 5) Run out in front of her and then away from your truck with a cup-cake in your hand
That wheel is bound to come off
Old Jan 18, 2010 | 07:03 PM
  #40
dwnhiller93's Avatar
Step 3) Find her:
Dude.. Thats my mom...
