Replacing W56
Old Aug 5, 2020 | 08:03 PM
greendevil's Avatar
Replacing W56
Hey all,
I have a '91 2wd and am scouring junkyards for a W56 trans to replace my clapped out unit which is slowly grinding itself to bits... does anyone know which years of 2wd 22RE piclups have the W56? Are there any differences between years I need to be aware of before grabbing one at random and throwing it in my truck? Or are there any other manual transmissions that came in these trucks that I should avoid?
Old Aug 6, 2020 | 05:40 AM
keycw's Avatar
5 Year Member
yes, there are A, B, and C models IIRC. they vary in shift mechanics. the marlin crawler website has a chart with all transmission models and years applicable.
Old Aug 6, 2020 | 05:49 AM
greendevil's Avatar
thanks!
Old Aug 6, 2020 | 07:48 AM
wallytoo's Avatar
the 2wd versions will be different than the 4wd versions. the 2wd version has a tailshaft for connection to the driveshaft, while the 4wd version will have no tailshaft, and might have a transfer case attached. a 4wd version would need a tailshaft added (at a minimum) to work in a 2wd truck.
Old Aug 7, 2020 | 09:59 AM
greendevil's Avatar
okay makes sense. the local pick-n-pull has an '89 2wd 22RE so I'll check it out. thanks!
1987_yota
Jan 23, 2020 06:05 PM
the_supernerd
Jul 16, 2012 10:46 PM
Bri85yota
Nov 21, 2011 08:50 AM
andy3542
Aug 24, 2011 02:23 PM
Five1Nine8Eight
May 25, 2006 04:43 PM
