Replacing a 7/8" master cylinder with a 1"
Old Oct 31, 2013 | 04:35 PM
oldblue's Avatar
try adjusting the rear brakes
Old Oct 31, 2013 | 05:26 PM
nothingbetter's Avatar
Glad to hear the MC works for you! Oldblue got it. Lots of times the adjustment on the rear drums is out to lunch. The self adjusters are unreliable at best. Pop off the drums and adjust them out a bit and try again. It can be a pain if your drums are getting worn as they'll have a lip on the outside edge. I ground the lip off mine when I still had drums.
And yes, you also have to bleed your proportioning valve. Assuming they have on of the 2wd. I'm not sure on your year but on mine its attatched the the passenger frame rail above the axle. Follow the brake line and you'll find it. I warn you in advance, use penetration oil on the bleed screw in your PV. Also, use a socket the first time you undo it, Heat may be useful as well. I've wrecked a few of the bleed screws. They don't get washed off often and many people forget about them when bleeding so they rust themselves in place. I bleed the pv, bleed your 4 brakes, then the PV again. No problems yet.
sandyota
Feb 4, 2021 11:16 AM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
cars-guy
Jul 11, 2015 07:51 PM
