Replaced front main seal and O-ring but still leaks?
Old Jul 24, 2012 | 10:02 PM
4runner_guy's Avatar
Hey guys, I recently did a timing chain replacement, head gasket replacement, front main seal and o-ring for the oil pump (22RE engine with 250k). All parts are OEM from the dealership and I used the FSM quite often to help me trouble shoot. I drove the truck for a week and opened the hood a few days ago to find out that I had oil all over the front of the engine; belts, hood, front chassis, and etc.
So it led me to believe that the front main was possibly installed wrong or o-ring might of gotten pinched during the install so I went ahead and bought me another set of o-ring and front main seal from the dealership today. Pulled everything off and pressure washed her down to get a better idea of where the potential leak is coming from and replaced both the parts adding RTV silicone on the oil pump and the top bolt. Got done with the job a few hours a go and drove around for nearly 10 mins, parked her and still leaks!! WTF.
Any ideas of what I could be doing wrong? Timing chain cover shows no signs of leaks, no dripping from crank pulley, but sprays a crap load of misty oil all over the place, I need some guidance please, so if anyone could help shed some light on this frustrating issue, it would be greatly appreciated, thx.
Old Jul 25, 2012 | 02:12 AM
vital22re's Avatar
totally a bro
Your crank pulley has a ring worn into it from the front main seal. You can either replace the whole unit, or pick up a repair sleeve kit from an aftermarket auto parts place.
Old Jul 25, 2012 | 08:42 AM
I see, I guess it's time to open up my wallet again and get this replaced ASAP, thx, I'll give an update once this is cured.
Old Jul 25, 2012 | 09:59 AM
OrRunner's Avatar
use a MICRO SLEEVE before you put on your front main seal. 6-10 bucks
Old Jul 25, 2012 | 07:56 PM
drew303's Avatar
common issue, you can cheat by not putting the seal all the way into the oil pump maybe a 1/16" off from where it normally sits to make contact with virgin metal on the front pulley...
or use a repair sleeve "speedy sleeve" ive seen em called. I havent installed one before so i cant tell you how easy it is or tools required? I need to put a repair sleeve on my 87 actually.. leaking again.
Old Jul 25, 2012 | 11:13 PM
Well, went ahead and put the speedy sleeve on and torqued her down to 116lbs and drove for 10 mins....no leak so far. Its progress for the most part so I'll revive this thread in the next 100 miles and see how she holds up. But this is what I did:
Worn grooved harmonic balancer:
New sleeve:
Sleeve installed onto harmonic balancer with locktite:
Old Jul 30, 2012 | 10:49 AM
annoyingrob's Avatar
Or you can try a seal from an early 22R motor. They sit in a slightly different spot on the crank as well. That's how I fixed the leak on my 83, with a seal from an 85+.
Old Jul 30, 2012 | 09:43 PM
Well, ended having a much bigger problem, but on the way to a rebuild, look here
http://board.marlincrawler.com/index.php?topic=90270.0
Old Aug 3, 2012 | 08:26 AM
The process is under way......
Valve cover, timing cover, radiator, and pulleys off:
Starter next in line:
Valve cover and intake manifold super dirty:
Valve cover cleaned and ready for paint:
Intake manifold cleaned:
Alternator, hoses, pipes and brackets cleaned:
Old Head ready to retire and reuse the rocker arm assembly:
Rocker arms still looks good no? I think so:
Look what just came in!! Early birthday present to myself, Engbldr's Street RV head, waiting for 268 cam and rocker arm assembly:
Block is at the machine shop, once I get the specs from the shop, I'll order the master kit from engbldr, hope to get her running in the next few weeks!
voiddweller
19
May 2, 2016 09:10 PM
Alaskan91
Sep 21, 2015 04:39 AM
ian1386
Jul 1, 2015 11:23 AM
crazypaint
Jun 23, 2015 03:27 AM
AustinTaco
Jun 21, 2015 09:54 AM
