Removing intake plenum and manifold...PITA!
Old Dec 4, 2006 | 07:32 AM
DudeBud's Avatar
Originally Posted by rdlsz24
Is there something that can be done for a warped head, or should I just spring for a new one? It seems to be warped right where it was leaking down the block.
Rob
find a machine shop and have them resurface it. make sure that the cam turns freely before that!!!!!!!!!!
Old Dec 4, 2006 | 07:48 AM
rdlsz24's Avatar
Would I need one of those thicker head gaskets then since the head won't be as thick? I already bought a standard head gasket and head bolts.
I want to make sure I do this right the first time so I don't have another leak in 6 months.
Rob
Old Dec 4, 2006 | 10:09 AM
fire5's Avatar
Look on the underside of the head. There are 3 or 4 dimples on one side(intake or exhaust-not sure which). If you can still see them you should be OK to have it milled. Just don't go beyond those markers.
Old Dec 4, 2006 | 11:50 AM
rdlsz24's Avatar
OK thanks I will take a look.
Rob
Blamalam
Mar 12, 2022 07:34 AM
Doug4320
Mar 24, 2018 10:11 PM
wafoogalla
Nov 2, 2016 11:02 AM
Flossy
Aug 5, 2015 05:14 PM
