Removing bed 93 ext cab 4wd
Old Nov 5, 2015 | 02:53 AM
Zach_trun's Avatar
Hello everyone my search for a bed is over. I found a rust free bed finally and just got it home the other night. Last night I took off the inner fenders and mudflaps, and got all the surface rust off the bed, then I power washed it. Alot of the bolts broke off so that is what I am gonna be working on tonight. After I get all the bolts I need I am going to chassis saver the underside of the bed. I was wondering if anyone could inform me on how many bolts and where at on the truck I am gonna have to take out to get my old bed off. And any other things I should do to this bed before I put it on the truck, thanks. The new bed is white, old bed is the green one
Attached Thumbnails Removing bed 93 ext cab 4wd-20150906_091535.jpg   Removing bed 93 ext cab 4wd-20150906_091521.jpg   Removing bed 93 ext cab 4wd-20151104_065203.jpg   Removing bed 93 ext cab 4wd-snapchat-6111317259514801022.jpg   Removing bed 93 ext cab 4wd-20151104_065154.jpg
Old Nov 5, 2015 | 05:07 AM
dropzone's Avatar
Fossilized
if you mean just the 6 bolts that hold it to the frame there are 3 on each side
- when you go to remove your bed, be sure to undo the fill hose for the gas tank
- swap the lock for your gas door to the new bed
Old Nov 5, 2015 | 09:21 AM
Terrys87's Avatar
Start soaking the bolts with PB Blaster. If you are going to be using the old bolts, I suggest using blue locktite. It seems no matter how tight I retighten the bolts, they tend to loosen up without locktite on them.
Old Nov 5, 2015 | 10:44 AM
Zach_trun's Avatar
I'm getting all new bolts
twasabug
29
Feb 26, 2016 11:11 AM
92truckowner
12
Nov 16, 2015 03:34 PM
voiddweller
Oct 31, 2015 01:27 PM
Obmi
Oct 25, 2015 08:24 PM
jjrbus
Oct 18, 2015 10:56 AM
