rearend swap ?
Old Oct 21, 2009 | 06:25 PM
jimep's Avatar
Originally Posted by Junkers88
Are you saying that the drop outs are different depending on what springs they have?
no, just saying the 4 cyl and 6 cyl 3rd members are different but interchangeable. the axle housing's aren't interchangeable from *89 and older to 90 and newer. I stand corrected on that year typo... Can't bolt coil springs and control arms up to leaf spring perches.
Old Oct 21, 2009 | 09:49 PM
Junkers88's Avatar
Oh got it! I was thinking that my parts field had just been limited. *sigh* Parts are so hard to find that I was worried.
Oh and just for fun. Coils (have to look close) on a leaf sprung housing.
Front end to show I didn't pick half the tires...... don't laugh at the "flex".
Old Oct 22, 2009 | 07:58 AM
75k5toy's Avatar
Originally Posted by DeadGame420
Man I hope thats all it is.
Don't forget to check the axleshaft bearings.
Old Oct 22, 2009 | 04:57 PM
kornhuskerwizard's Avatar
so how do you identify what gear ratio you have on the ring & pinion? Just wondering cause im wanting to swap rearends from a 86 to my 88 4x4 truck.
Old Oct 22, 2009 | 05:51 PM
  #25
Tofer's Avatar
Sponsor
holy crap this thread has some BAD info in it.........
to set the record straight:
* YES 79-95 8" 3rd members from either truck/4runner will go into any 8" housing... FRONT or REAR
* V6 housing use bigger bearings and 4 spider gears in the carrier which make them stronger than 4cyl which has the smaller bearings and 2 spider gears. _HOWEVER_ you can use 4cyl housing with a V6 without *many* issues. I've been running a 4cyl with a lockright in the rear of my 89. (while i am having lockright issues, the housing and gears are soild). my brother has been running 456 4cly open in the rear of his pickup for years. If you do a 350 swap, you'll most likely want the v6 housing.... otherwise the power (or lack of power) the 22re/3vze create aren't an issue. you can itenify the difference between the V6 and 4cyl housing based on the number of "ribs" they have.... V6 have 4, 4cyl have 3 as see here:
* 79-85 rear ends are narrower than 86-95. so while the 3rd member is inter changeable the axle shafts are not. the Drum are also smaller on pre 86 axles.
*79-95 Pickups and 84-89 4runners are leaf sprung (unless otherwise molested) 90-95 4runners are coil sprung (agian, unless otherwise molested)
* there are several "oem" gear ratios available.. make sure you get the correct one to match your existing ratio when pulling one from the J-yard... otherwise you'll be back here asking which transfercase you need to pull from said J-yard.
* you can tell the gear ratio by several methods: Color code, VIN code, or simply counting teeth.
* Color code method: toyota painted the Pinion end from the factory:
410: Pink
430: Blue
456: Yellow
4:88: White
VIN code:
410: G292/G294
430: G282/G284
456: G254
488: G144
Counting the Teeth Method
410: 41(r)/10(p)
430: 43(r)/10(p)
456: 41(r)/9(p)
488: 39(r)/8(p)
* IF you use *Factory* 4.88 gears, you are _UNABLE_ to regear them later. factory 4.88s use a offset pinion, that only work with that ring/pinion set.
* IF your pinion nut loosened up, you _CANNOT_ just tighten it back up... you have NO way of knowing the pinion depth/backlashing on the gears and will most likey blow them up shortly there after.
Old Oct 22, 2009 | 07:32 PM
  #26
jimep's Avatar
410: Pink
430: Blue
456: Yellow
4:88: White
VIN code:
410: G292/G294
430: G282/G284
456: G254
488: G144
410: 41(r)/10(p)
430: 43(r)/10(p)
456: 41(r)/9(p)
488: 39(r)/8(p)
good post. kinda along the lines of what I was trying to say. (except for getting wrong years in for the coil sprung 4runners). Aso 2 small thing u forgot to mention. 85 and older have smaller rear drums... V6 (4wd) thirdmembers identifiable by 4 ribbed flanges running horizontaly, 4 cyl(4wd) only had 3... Now I think we covered EVERYTHING
Old Oct 22, 2009 | 08:24 PM
  #27
Tofer's Avatar
Sponsor
edited to include your suggestions.
Old Oct 23, 2009 | 12:40 AM
  #28
awareness's Avatar
Sometime ago I was wondering how much trouble it would be to swap in a T100 or Tundra rear into a 86-95 Pickup for the sake of getting closer to the track width of a Total Chaos LT front setup (this would make the rear around 3" wider than the TC setup in the front?).
Anyways, gears aside, how easy or hard might this be to do?
Old Oct 23, 2009 | 11:47 AM
  #29
jimep's Avatar
just looked at my 00 2wd tundra and it looks close. 6 lug. same style ebrake it looks like although it comes down from the drivers side of the frame. u might have to relocate spring perches though, shock brackets will deffinatly need relocated.
Old Jan 27, 2011 | 02:57 PM
  #30
MudHippy's Avatar
Excellent post. Except for this part. Which is wrong.
The torque load on the pinion nut doesn't affect the pinion depth or the backlash(ring gear or side gear).
Pinion depth is set by the shim directly behind the head of the pinion gear. Pinion depth isn't changeable except through replacing that shim, and/or by wear that might occur to the inner and/or outer pinion bearings.
Ring gear backlash is set by either shimming the carrier bearings(7.5" differentials), or by turning the carrier bearing preload/ring gear backlash adjustment nuts(8" differentials).
Side gear backlash is set by shimming the side gears.
The pinion nut only controls drive pinion preload. Though that can technically be called a type of "backlash" measurement, that's highly misleading to those who aren't familiar with what it actually measures. Which actually isn't "backlash" at all, but is instead the combined preload of the pinion bearings and carrier bearings. The measured backlash between the drive pinion and ring gear, or simply the ring gear backlash as it's commonly refered to, has nothing to do with it in reality. So to call it the "preload of the backlash between the drive pinion and ring gear" is nearly non-sensical. Why Toyota chose to use those terms is beyond me. I'm just glad I know better.
15. ADJUST DRIVE PINION PRELOAD
Using a torque meter, measure the preload of the back–
lash between the drive pinion and ring gear.
Preload (starting):
New bearing
7.5 in.
1.2 – 1.9 N–m
(12 – 19 kgf–cm, 10.4 – 16.5 in.–Ibf)
8 in.
(2 pinion type)
1.9 – 2.5 N–m
(19 – 26 kgf–cm, 16.5 – 22.6–lbf)
(4 pinion type)
1.0 – 1.6 N–m
(10 – 16 kgf–cm, 8.7 – 13.9 in.–Ibf)
Reused bearing
7.5 in.
0.6 – 1.0 N–m
(6 – 10 kgf–cm, 5.2 – 8.7 in.–Ibf)
8 in.
(2 pinion type)
0.9 – 1.3 N–m
(9 – 13 kgf–cm, 7.8 – 11.3 in.–Ibf)
(4 pinion type)
0.5 – 0.8 N–m
(5 – 8 kgf –cm, 4.3 – 6.9 in.–Ibf )
(a) If preload is greater than specification, replace the
bearing spacer.
(b) If preload is less than specification, retighten the nut
13 N–m (130 kgf–cm, 9 ft–lbf) a little at a time until
the specified preload is reached.
Maximum torque:
7.5 in.
235 N–m (2,400 kgf–cm, 174 ft–lbf)
8 in.
343 N–m (3,500 kgf–cm, 253 ft–lbf)
If the maximum torque is exceeded while retightening the
nut, replace the bearing spacer and repeat the preload
procedure. Do not back off the pinion nut to reduce the preload.
http://personal.utulsa.edu/~nathan-b...35differen.pdf
I'm not trying to pick on you. I just came acrossed your post linked to in a "newbie information" section, and it wouldn't be fair to lead the "newbs" down the wrong path. As you most certainly _CAN_ retighten the pinion nut without fear of gear failure, if you know what the torque setting and preload measurement should be when you do. And provided that the pinion bearings, inner and outer, haven't worn significantly enough to cause the pinion depth to change dramatically. Which isn't too likely unless they've been run without the proper preload for quite some time. Meaning, you can almost always just retighten the pinion nut and be fine. People do it all the time.
Old Jan 19, 2013 | 10:51 PM
  #31
day1977's Avatar
can i put a 84-85 4.10 3rd member on my 91 rear axle?
Old Jan 20, 2013 | 01:41 AM
  #32
iliketoyota's Avatar
yes all pre 96 8 inch 3rd members are interchangeable
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
GeoRoss
Jul 24, 2015 03:03 PM
