Rear U-joint: tough to grease
Old May 13, 2010 | 11:12 AM
de6w6it's Avatar
Originally Posted by Jay351
Yea you need to keep constant pressure on the needle or else the grease won't go into the fitting.
i was pressing pretty hard, but it still came out. i guess one (or both) of two things going on, enough grease in there, and instead of it squirting out the caps, pressure came out from needle contact surface to zerk, or i wasn't holding it square enough on the surface of the zerk, and it was squirting out the side.
try, try, again.........
Old May 13, 2010 | 03:50 PM
Jay351's Avatar
Try poking the little ball down with a tiny Phillips screwdriver. Sometimes they get stuck.
If you can't get any grease in there its probably full.
On new u-joints when they are full they usually spit the grease back out the fitting, on older joints it all comes out of the caps.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Lochsa
Aug 2, 2015 02:51 PM
calderp
Jul 27, 2015 09:58 AM
PlayAwhile
Jul 20, 2015 11:36 AM
icentropy
Jul 14, 2015 10:23 AM
