rear springs
Old Jul 3, 2008 | 08:35 PM
just a 22re's Avatar
if you have a 4in lift why are you trying to replace the rears?
and not a high jack but just wondering now 63 chevys give you 4in of lift?
Old Jul 3, 2008 | 08:38 PM
toyotanick's Avatar
because i have blocks in the rear and i was told that 63 inch chevys give you 4 inches. probably because a stock toyota spring has no arch in it and im guessing that the chevy ones have arch
Old Jul 4, 2008 | 04:59 AM
dirtoyboy's Avatar
meh, not really...they are actually a pretty flat spring....the flatter the spring the more flex you get.....more arch = less flex = rougher ride....
The chevys give about 2 inches of lift by themselves over stock
Old Jul 4, 2008 | 06:35 AM
ah so then a set of chevys and a longer shackle will get you the 4in you are after for about 240 bucks not bad for a rear kit
and yes you might wanna dump the rear blocks asap!!!
Old Jul 4, 2008 | 06:49 AM
  #25
toyotanick's Avatar
so the rest of the lift is shackle?
Old Jul 4, 2008 | 06:55 AM
  #26
dirtoyboy's Avatar
Most people that run Chevys run one or two inch blocks to even out the lift on the front.....
Old Jul 4, 2008 | 07:40 AM
  #27
toyotanick's Avatar
ah, well then im not going to do chevy springs because i thought i was told it would give me 4 inches. instead of using a block at all
Old Jul 4, 2008 | 07:47 AM
  #28
dirtoyboy's Avatar
The 4 inches usually comes from the one or two inch blocks underneath (which is fine in MOST cases....but can cause sever wrap if not set up properly) Most people that run this set up are trying to match their lift on the front when they do a solid axle swap....
It might be very possible to do just the springs (no blocks) and have it match your front IFS lift...you would have hella flex in the rear!
go here for all your chevy spring needs>>
http://www.pirate4x4.com/forum/showt...threadid=20665
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
terminator
Jul 27, 2015 07:13 PM
yourrealdad
Jul 21, 2015 11:13 AM
Nickdigg
Jul 7, 2015 06:04 AM
