Rear Shackle Mount Question
Old Aug 17, 2012 | 06:22 AM
johnboy68's Avatar
Does anyone know where I can get a new rear shackle mount to weld on the frame?
My 89 Pickup's rear mount is pretty rusted out and I would like to weld a new one on.
I've done a search and can't find the answer. I'm new to this forum so I haven't quite found my way around yet. I'm sure I will, I'm doing a basic 50% rebuilt of this Pickup (i.e. fixing the rear area of the frame, putting in a rebuilt 22RE, small lift and new paint).
Thanks
Old Aug 17, 2012 | 06:25 AM
waskillywabbit's Avatar
http://www.wabfab.org/Rear-Spring-Ha...ypage.tpl.html
:wabbit2:
Old Aug 17, 2012 | 06:37 AM
johnboy68's Avatar
Originally Posted by waskillywabbit
Those look like the exact same ones I got from Low Range Off Road. They even list the exact same description. The problem with those is they are much narrower than the OEM mounts. I have new bushings and new shackles and the bushings/shackles are too wide for them. I need mounts that are the same width as the OEM ones.
Old Aug 17, 2012 | 06:45 AM
Then you are going to have to make you're own I'm afraid or you're SOL.
:wabbit2:
Old Aug 17, 2012 | 07:03 AM
johnboy68's Avatar
I was afraid of that. So you are saying that there are no aftermarket mounts that are OEM width?
Old Aug 17, 2012 | 01:03 PM
87 4x4's Avatar
making shackes is easy. 2 pieces of plate with the same holes and if you want to get fancy a support piece in between really simple
Old Aug 17, 2012 | 02:44 PM
donomite49's Avatar
thought about doing a 63" chevy spring swap?
http://www.nwtoys.com/content/135-ch...-swap-faq.html
Old Aug 17, 2012 | 03:06 PM
mike86yota's Avatar
i bought those shackle mounts from wabfab and they were the same width as my OEM ones on my 92 pickup...so i dont know why 89 would be different.
87turboPA
Jul 12, 2015 07:49 AM
jon.r
Jul 11, 2015 03:34 PM
87turboPA
Jul 9, 2015 05:58 AM
skoti89
Jul 8, 2015 12:05 AM
