rear sag fix with no lift?
Old Jan 26, 2008 | 07:57 AM
Belize Off Road Team's Avatar
i don't know what you are talking abou infiltrator...i have the PP 1" lift progressive springs, for over 20,000kms they have stayed at their ride height of when i first installed, just look at my before and after pics! i spent money on proper 1" springs, if you buy no name or cheap brads, YES they will return to stock height. duh...
Old Feb 3, 2008 | 02:02 PM
Brenjen's Avatar
Well, got the springs & Bilsteins in there today, took about 3 - 3 & 1/2 hours. The truck was lifted 3'' exactly, from 2' 9'' to the bottom of the wheel well before to 3' even after. A little higher than I wanted but after I get new tires & remove the running boards it'll look a little better, plus now I can actually carry a little gear in the back without bottoming out lol.
I took a before & after shot ( well the wife did, I'm not allowed to touch her camera for fear I'll have the urge to give it more power ) As soon as we get the pics onto my P/C I'll stick a couple on here.
Thanks again for the tips people!
Old Feb 3, 2008 | 02:57 PM
Brenjen's Avatar
BEFORE
AFTER
In the after shot you can see the 2x4 has a gray mark, that's the 2' 9" mark where it sat stock, the board was exactly 3' long so no mark was needed & I just stood it up against the wheel....I know it looks like the board is under the wheel well lifting it up but it isn't.
Now I need to take off the running boards, get new tires, put on my new pads & rotors, lube my spindle bushings & slap in some ARB's!
Old Feb 3, 2008 | 03:55 PM
xcmountain80's Avatar
Lookin good!
Aaron
Old Feb 3, 2008 | 07:28 PM
  #25
bigarms23's Avatar
on my friends 4runner we used a set of 2wd ford 150 coils and it made his 4runner level
Old Feb 3, 2008 | 07:55 PM
  #26
Brenjen's Avatar
This will probably sit a little better. The picture was without the spare tire on a 1/4 tank of gas & nothing in the cargo area. Once the spare was put in, kids in the back, full tank of gas, camping gear etc. it will probably be just about perfect. Maybe a tad high but not so much that it bothers me, once I get new tires & get the running boards off I may tweak up the T-bars a little; I'll just have to wait & see how it goes.
Old Feb 4, 2008 | 05:57 AM
  #27
Victor's Avatar
Are you happy where its at or are you going to lift the front a little? I'd say BJ spacers will help level it plus you can relax the torsion bars a little and get a better ride. I personally like the way it looks now. Mine sits the same with the back a little high but I'm 1.5" higher than you.
Old Feb 4, 2008 | 09:38 AM
  #28
Congrats on the new look! i hope you are enjoying the new ride!
Old Feb 7, 2008 | 10:46 AM
  #29
tibbycruiser's Avatar
Shock shop has some airshocks that would work, they are gabriel P/N=39511
You would have to take out the bushings and insert poly bushings drilled to accept your pins.
Old Feb 8, 2008 | 12:53 PM
  #30
tank1's Avatar
will this work on trucks as well???? Have 94 ext cab that sags just wandering
Old Feb 13, 2008 | 04:24 AM
  #31
Brenjen's Avatar
I'm not really sure what I'm going to do yet in all honesty. I just took the running boards off (did I mention that already?) & am in bad need of new tires. The tires I want are Yokohama Geolander M/T plus but no one around here can seem to get them., I need to rebuild my front rotors & do a brake job too & even though I have the parts to do it, I'm waiting on a pair of Aisin hubs I bought from a guy on here & I also want to look into the spindle bushing & see if it needs replaced. As far as T-Bars, I was looking into a pair of OME's to replace my stock bars. I think the 25mm & 26mm might be too stiff for me. And the work will go on etc. etc. ad nauseum.
If I end up doing a Total Chaos long travel IFS kit then there's no need to waste the money on BJ spacers, new CV's etc. I have a lot of work yet to do before I decide what the final outcome is gonna be.
Old Feb 13, 2008 | 04:29 AM
  #32
Brenjen's Avatar
Yeah the ride is better but I'm not really going to notice the difference until I load it down. It's still on a 1/4 tank of gas even lol
Old Feb 26, 2008 | 08:15 AM
  #33
Brenjen's Avatar
Well, now that I have the new tires on there they rub a little at full steer left or right. I haven't had a chance to see what they're rubbing on.....sounds like the plastic splash guard. I had the 31x10.5's put back on there so no size increase on that. Thinking of putting a 1" BJ spacer kit on it but my front shocks aren't that old (1 year) & new shocks would add to the install cost if they were needed.
I figured it would be a good time to do it if I'm going to since I just got all new front end parts from arm_can; a seller on e-Bay and will have the entire front end apart in a few days. I might even add some OME torsion bars.....still up in the air about what to do. Much more reading & figuring in my head & decisions lol
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
akaphilly
Jul 9, 2015 02:18 PM
Nickdigg
Jul 7, 2015 06:04 AM
Vargntucson
Jul 4, 2015 12:15 PM
