rear pumpkin install. stuck partway
Old Feb 25, 2009 | 05:26 PM
dewiseman's Avatar
shaft wont go in
Originally Posted by muddpigg
LOL, thats how we got a family. Wrenching women are hhottt.
WOW, I think I will pay someone else to instal my locker. Sounds alot less expensive than ending up with a family from it.lol MuddPigg best of luck to you buddy. Stay safe.
Old Jul 4, 2009 | 11:35 AM
Stuwy123's Avatar
Rise Dead Thread RISE!!!
I've pulled a couple diffs from the wreckers but I've always had a problem with the brake lines. I usally just beat them around enough to get the axel outta the diff.
I've never dealt with brake lines before and now it's time to install some diff into my truck.
Do you have to bleed the brakes after you pull the lines off? I've never done that before. I'm hoping for an easy way around that. I've heard you can just wrap the ends with a plastic bag to keep it from collecting too much air.
Does this work?
Old Jul 4, 2009 | 11:42 AM
mojo4x420's Avatar
Bleed them. It takes 10 minutes and brakes are important. New brake fluid is always good.
The bag trick kinda works, but I always find it leaks and unless you are really quick, you'll end up dripping fluid everywhere and possibly running your master dry. If your master runs out, you should really remove it and bench bleed it. Shaved golf tee's in the brake lines work better. But bleed anyways.
icentropy
Sep 16, 2020 02:47 PM
fountain
Dec 31, 2015 06:08 AM
CanRunner
Jul 20, 2015 01:29 PM
icentropy
Jul 14, 2015 10:23 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
