rear main seal replacement
Old Aug 27, 2010 | 10:47 AM
Leethaxor4u's Avatar
Alright I am gonna admit right outta the gate I didn`t use the search feature on the forums so don`t flame me. I am in a super hurry and am trying to figure out what to do. I will search after I post this in hopes you can answer faster than I can find it.
I am replacing the rear main seal. It didnt leak at all but rather the housing holding it leaks. Moreover it leaks on the surface that mates to the oil pan gasket does. When I removed tghe housing there wasnt a gasket on the bottom. Just sealer. and the bottom 2 bolts or the oil pan bolts were loose.
I went to the local napa and the broad behind the coun ter showed me a pic of the oil pan gasket. The actual gasket covers the spot under the seal housing. So should I replace the entire oil pan gasket or just add sealer to the bottom of the housing and reinstall?
Old Aug 27, 2010 | 10:50 AM
T_F_E's Avatar
Sealer should work fine, thats what i use for oil pan gaskets anyway.
Old Aug 27, 2010 | 11:18 AM
Thanks!
warrenjcarlson
Jul 22, 2016 11:47 AM
voiddweller
19
May 2, 2016 09:10 PM
jennygirl
Nov 17, 2015 11:24 AM
Alaskan91
Sep 21, 2015 04:39 AM
cchinny
Jun 25, 2015 08:11 PM
