Rear ends
Old Jan 3, 2016 | 08:59 AM
creedua's Avatar
Rear ends
Will rear from 91 truck fit under 95 4 runner
Old Jan 3, 2016 | 10:32 AM
wyoming9's Avatar
Red face
Sort of if you change all the Suspension hard points around.
Fire up the welder and the compressor and Air Arc ( plasma if you have it)
the parts you no longer need
One is a leaf spring Suspension and one is a coil spring at least when they left the dealer the first time.
Old Jan 3, 2016 | 11:16 AM
creedua's Avatar
Could I just change 3rd member
Old Jan 3, 2016 | 12:47 PM
dropzone's Avatar
Fossilized
^^yes--> as long as the gear ratio matches
Old Jan 3, 2016 | 01:14 PM
MudHippy's Avatar
^^And it has/doesn't have ABS. Depending on which is/isn't required.
Marc
10
Dec 28, 2015 01:08 PM
mj928
Nov 7, 2015 10:45 PM
Gunnar Kristjansson
Nov 4, 2015 02:33 PM
edgar62902
9
Oct 15, 2015 11:30 AM
skouba
Oct 10, 2015 05:15 AM
