Rear end noise?
Old Mar 20, 2011 | 05:18 PM
pinoaktwh's Avatar
"spreadin her legs so i can go to town on her "
I was amused with that statement accompanying the pic. I'm glad you got it figured out.
Thats what I like about this site. People can throw ideas for ya to look into. I usually am able to dismiss most of them until one comes along that I can't, and when ya get to looking it usually comes to light. One of them will get it tho. Keeps me from chasing my tail.
I have never bought a junkyard Diff. I have no advice for ya on that one.
Good luck
Larry
Old Mar 20, 2011 | 09:24 PM
peow130's Avatar
Originally Posted by camo31_10.50
i'm going to also replace the bearings and seals on both sides..
Currently on the lookout for a 4.56 diff, theres 2 in the junkyard one town over...but i'm not sure if they're good or not.
what should i look for when buying a junkyard diff? Besides the obvious like a chipped tooth on the ring or pinion...or not spinning smooth lol
Rust on the gears would be the cause of cencern.
Generally means that the diff has been submerged in water.
And the bearings could be smoked.
i mean, otherwise, if the gears look to be in good condition, with no cracks or chips, and theres no play in the pinion flange, then buy it.
But certainly don't mess with it, lol.
Old Mar 22, 2011 | 08:29 PM
camo31_10.50's Avatar
now i need to find a 3rd member.....i remembered the axle codes from the 4runners and trucks in the local yard...one was 4.56s....and the ring gear has 5 chipped teeth.....dangit...
so now i'm lookin for a 4.56 rear end.....or a set of 4.88's and i'll regear LOL
Old Apr 7, 2011 | 12:47 PM
found a set of 4.88's in good shape for $500(for both diffs)....and i found a 4.56 diff for ~$100......i want the 4.88's, but i need the 4.56s...so tomorrow i'm getting confirmation from the junkyard and i'm prolly going to go get em this saturday or next week, i'm also going to be doing rear bearing and axle seals....anyone have any tips or tricks i'd be more than happy to listen....or well read
Old Apr 7, 2011 | 01:35 PM
  #25
anthony1's Avatar
You could buy a set of 4.56 gear/ pinion and bearing kit and have someone do it for you. It should be less than 500.
Old Apr 7, 2011 | 02:14 PM
  #26
blake.nemitz's Avatar
ill find the pic of mine i had 4 teeth gone and two clunks a round
Old Apr 9, 2011 | 08:54 AM
  #27
all the shops want over $700 to do it...i've called about 15 different places..most were around $800-$900 and as high as $1100...
no go on the junkyard diff it was a Nissan Pathfinder? piece of crap junkyard said it wa sa 4runner....
Old Apr 16, 2011 | 10:30 AM
  #28
i grabbed ahold of my brake drum, and went to pull my axle out a little and it felt likes the bearings were BAD....like BAD BAD...i could wiggle my drum like 1/4".
So this means my bearings are bad correct? i wouldn't think i would be able to move my drum at all...correct?
Old Apr 16, 2011 | 11:31 AM
  #29
yotarover's Avatar
as soon as i find out, how much it's going to cost to install my spool and 5.29's. my 4.56's are up for sell. unless i can find 2 5.29 diff's
Old Apr 17, 2011 | 09:36 PM
  #30
there was 2 5.29 differentials in the Tulsa Oklahoma craigslist (auto parts) for sale...dude was parting out a lifted 4runner...had a locker in the rear..and a 7.5" 5.29 front.
gonna replace my bearings and axle seals this week...and probably make a trip to set Govt.Mule and buy his 4.56 diff he has...unless i can find a better deal
Old May 9, 2011 | 03:11 PM
  #31
Figured i'd update this...got everything back together, truck drives great except for a small vibration..i believe my driveshaft is out of phase, so easy fix..i'll report back if i find a more serious problem
thanks for all the help and input guys
Old May 9, 2011 | 04:22 PM
  #32
anthony1's Avatar
Awesome! So what did you end up doing?
Old May 9, 2011 | 05:31 PM
  #33
Oops lol...i put a rear diff in that i bought off of a fellow Yotatech guy named Mike!
So far so good...
Daneums
Aug 20, 2015 05:36 AM
razorman8669
Jul 12, 2015 12:13 PM
hangtown88toy
Jul 10, 2015 02:33 PM
akaphilly
Jul 9, 2015 02:18 PM
toyoda8488
Jul 5, 2015 10:18 PM
