No Btm-end Power
Old May 9, 2011 | 05:28 PM
Ole' Red's Avatar
No Btm-end Power
I have just replaced a head gasket on my 89 22r-e. I was quite meticlous about labeling everything and putting it back where it came from, however the truck is second hand and I believe the head has been replaced before (it has the pear shaped ex ports). I can not figure out why but the truck has NO power. It seems to have plenty of power at high rpm's but if I do not drive it like a motorcycle I couldnt make it up the first hill I come to down the rd. This truck is my daily driver. I am lost and out of Ideas! the truck ran great prior to the hg blowing.
Old May 9, 2011 | 05:33 PM
xxxtreme22r's Avatar
Ignition timing set to FSM specs using the correct procedure? Distributor not 1 tooth off? and ????? 89 should have pear shaped exhaust ports.
Old May 9, 2011 | 05:40 PM
Ole' Red's Avatar
I thought the pear shaped ports were just on supras. yes it is timed.
Old May 9, 2011 | 05:43 PM
nope, round shaped exh ports were on an 81-84. 85-95 got the pears. Got to watch out for early 85's though, some of them still had the 84 engine in them.
http://www.lcengineering.com/TechNotes/?techid=49
Old May 9, 2011 | 05:45 PM
Ole' Red's Avatar
right on. thanks!
delmert
Sep 30, 2015 04:34 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
shisha1999
Sep 20, 2015 11:44 AM
agrout
Aug 13, 2015 06:12 PM
Sidherish
Aug 2, 2015 01:42 PM
