Rear Driveshaft Bearing or Bushing Gone bad?
Old Apr 18, 2008 | 05:56 PM
traben27's Avatar
I'm basically crossing this over from a thread over on UY since I know there's some more traffic on this site and I need all of the opinions I can get...
Here's the link...
I need to get this figured out before I drive over 1200 miles next week, so any help is appreciated
Old Apr 18, 2008 | 08:47 PM
traben27's Avatar
buuump
Old Apr 18, 2008 | 09:43 PM
AxleIke's Avatar
Not sure why you haven't pulled the case and taken a look. It takes all of an hour to pull it, and dissassembly takes even less time. You could have that thing on the bench, and check the rear bearing on a weekend day, order anything you need new, and have it back in a few days later.
From the description, it sounds like the transfercase pretty bad.
Old Apr 18, 2008 | 10:12 PM
abecedarian's Avatar
Just read your thread and it sounds, by what you've described, that there may be excessive play in the output shaft of the x-fer case. I could understand a tad bit (maybe 0 +/- 1 mm) of axial play (front to back). You should not be able to 'see' any vertical or horizontal play in it.
Old Apr 18, 2008 | 10:13 PM
traben27's Avatar
I would be doing a lot more myself on this, but I'm in the middle of ending a semester and doing finals right now so time is VERY limited.
Is the play found in the driveshaft typical? I thought there shouldn't have been any at all...
By the way, this play is the REAR driveshaft....I haven't looked too much at the front as I have manual hubs, so nothing up front should be even moving.
Old Apr 19, 2008 | 06:45 AM
Marc P's Avatar
I had the same problem a couple years ago....pulled the driveshaft and hit the nut with an impact wrench...no more problems.
Old Apr 19, 2008 | 06:09 PM
traben27's Avatar
Is this the nut thats on the tranny side inside that flange?
Old Apr 19, 2008 | 09:15 PM
Marc P's Avatar
Thats the one.
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
andrewtexas123
Jul 14, 2015 04:29 AM
Gamble_STi
Jul 7, 2015 07:54 PM
