Rear door will not unlock
Old Apr 19, 2011 | 04:48 PM
phinsbama2413's Avatar
Ok so this may be an idiotic question but here goes. On a 92 runner, is the ignition key the same key for the rear door? I cannot open it from the inside or outside!! Also, the rear window will not roll down. All of the fuses are good. Switch maybe?
CS
Old Apr 19, 2011 | 05:04 PM
michael1963's Avatar
CS
Yes your ignition key is the same for the rear door. Did you have it open and or apart before all this happened?
Old Apr 20, 2011 | 05:02 AM
No. I've only had the truck a couple of months and it's never opened. I'm not sure what it is. I'll keep playing with it and hopefully figure it out. I searched the forums but didn't see anything specific to my issue.
CS
Old Apr 20, 2011 | 05:55 AM
bigdaddy87547's Avatar
Make sure the window lock button is not pressed in. Just a thought.
Old Apr 20, 2011 | 06:04 AM
skoti89's Avatar
window lock button( both for rear too. I know mine is separate) Make sure all the plugs are intact inside the door panel, maybe test with test light? make sure nothing is jammed up.
Old Apr 20, 2011 | 06:34 AM
Team420's Avatar
The window has to be all the way down for the door to unlock... that being said... when u hit the switch to lower the window, do u hear anything? Click, hum, anything? If not, I'd 1st check the window switch itself... I've gone thru a couple... after a few years of coffee/soda/dirt and grime, the switch will not make contact, and cease to work...
Good luck
Old Apr 20, 2011 | 06:39 AM
camo31_10.50's Avatar
for the rear window, crawl in the back, and take off the driverside panel in the rear (it's big, and quite the B#$@% if ya know what i mean...
theres a relay block in there, all i did was give mine a few love taps, made my rear window work perfect lol
idk about the door though...
Old Apr 20, 2011 | 07:29 AM
MrPeepers's Avatar
LOL, yeah I thought mine was broken once and it was the window lock switch. Hopefully that is your problemn as it is an easy free fix. Good luck!
Old Apr 20, 2011 | 01:31 PM
You guys are going to love this. I sprayed a little lube into the key hole and it works perfectly. Got the idea somewhere online but don't remember where. Man what a cheap fix lol.
Old Apr 20, 2011 | 01:57 PM
James Woods's Avatar
Right on, my wifes runner was having the same problem the other day, I went to check it and found that she had hit the rear wiper switch and the wiper was torn I guess and it got stuck in the window so it wouldn't move and I guess unless the wiper is parked the window wont roll down either.
88sasturbotoy
Jan 30, 2026 01:57 PM
Jun 1, 2021 01:51 PM
Iceman4193
Jul 15, 2015 04:48 PM
icentropy
Jul 14, 2015 10:23 AM
hangtown88toy
Jul 10, 2015 02:33 PM
